23 Tooth top gear - HCS Snowmobile Forums
Apex / Vector / Rx1 This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 10-09-2009, 06:26 PM   #1 (permalink)
00sxr600's Avatar
Current Sled(s): 2007 Yamaha Apex GT
Previous Sled(s): 1991 Indy, 2000 sxr600
Favorite Riding Area: vermont
Riding Since: 2005
I have a 07 apex gt with a 121 inch track. Stock top gear was a 24 tooth and i want to do a 23. My question is am i going to have difficulty getting traction on a hard trail? I have 144 power point studs in it and i am wondering how badly i would lose traction compared to the 24 tooth. Any information is appriciated!
2007 Yamaha Apex GT - SLP straight line tracking skis, 13mm sway bar, pioneer performance clutch kit, pioneer performance revalved ohlins, big boy spring, 144 stud boy power point studs, cr10ek ngk plugs, 4th wheel kit, marginal snow wheel kit,23 tooth top gear, more to come...
1991 Polaris Indy 650- just bought, stock FOR NOW!!!
1999 Dodge 2500 Cummins Turbo Diesel, QCLB, 4" straight pipe, cold air intake, chipped...
2009 Yamaha Grizzly 450- brand new left over, black, my new toy!
00sxr600 is offline   Reply With Quote
Old 10-09-2009, 07:48 PM   #2 (permalink)
Member
779cookies's Avatar
Current Sled(s): 09 Apex RTX
I think you will improve your down low performance, you are going from 1.58 ratio to a 1.65, if you are keeping the 38 tooth lower gear and 70 link stock chain. You will scrub a little off your top end.
779cookies is offline   Reply With Quote
Old 10-09-2009, 09:07 PM   #3 (permalink)
00sxr600's Avatar
Riding Since: 2005
I dont mind the loss with top speed. I want it to pull harder off of the corners. What i am asking is with the better low end performance, how much more is it going to want to spin?
Old 10-12-2009, 04:27 PM   #4 (permalink)
Member
779cookies's Avatar
I dont mind the loss with top speed. I want it to pull harder off of the corners. What i am asking is with the better low end performance, how much more is it going to want to spin?[/b]
That will depend alot on your track and snow conditions, As you are already studded, how tall is your track height, Ripsaw ,Hacksaw, Cobra? Studded tracks will aways hook better down low than nostudded and will benefit more from the reduced upper gear, but the trade off is more track weight (top end) and more push going into the corners (longer carbides). The apex has lots of torque all through the power band, so loose snow or a pounded trail, I would expect more spin, but on hard pack that should translate to more go! The gearing on the 09 Apex rtx is 22/38 with a 68 link chain a ratio of 1.73. So in Yamaha's thinking, you are going in the right direction. Hope this helps.
Old 10-12-2009, 08:57 PM   #5 (permalink)
70superbee's Avatar
Current Sled(s): 2013 PRO R800 SWB ADV
Previous Sled(s): POO 600,650,700,800,900 YAMAHA ATTAK
Favorite Riding Area: Home, UP Mich.
Riding Since: 1980
Going to the 23 tooth is what many apex owners have done. My 06 attak came with 23-38 gearing and the best speed on really good hard pack and some ice is 128 on the dream meter. But for this year I put on extrovert drivers and a cobra track with 162 studs. So Iam going to loose a little on the top end but at least I will be able to go in soft snow.
You can either go with a clutch from Ulmer racing or super torquer both are very good.
Hope this helps some.
Rich
70superbee is offline   Reply With Quote
Old 10-13-2009, 04:45 AM   #6 (permalink)
Current Sled(s): 06 poo 600,2015 ape xtx
Favorite Riding Area: Patten
Riding Since: 1966
I have a 07 apex gt with a 121 inch track. Stock top gear was a 24 tooth and i want to do a 23. My question is am i going to have difficulty getting traction on a hard trail? I have 144 power point studs in it and i am wondering how badly i would lose traction compared to the 24 tooth. Any information is appriciated![/b]
You wont lose any top speed,i fact you will increase all speeds,including top speed,as the 24/38 geared ratio is way over geared for most sleds with 150 hp,if you were boosted to at least 230 hp you would be ok to stick with stock gearing,we have been playing with these gears for some time now,and with the stock ripsaw 1.25 and normal 96-144 studs you will be fine.
mnmsnowbeast is offline   Reply With Quote
Old 12-19-2010, 02:29 PM   #7 (permalink)
Member
so what gearing would you recommend for a bender turbo 136 rx1 cobra track no studs?
pontiacfreak is offline   Reply With Quote
