RS RAGE won't start, no fuel. - HCS Snowmobile Forums
Apex / Vector / Rx1 This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 10-13-2008, 03:32 PM   #1 (permalink)
Bought sled over the summer and its my first 4 stroke. Ran all summer when I tried, and now it doesn't get any fuel. I turn the key and don't hear a fuel pump (not sure if im supposed to). I have a shop manual, but its not very helpful. I checked all lines from tank to fuel pump and no clogs. I found 3 relays above right foot well, none seemed to be associated with fuel. Any ideas?
thanks, 2005 rs rage, 3 cyl
nqc2k is offline   Reply With Quote
Old 10-13-2008, 04:34 PM   #2 (permalink)
Got her started. Guess she just wanted to be primed.
Old 10-13-2008, 04:42 PM   #3 (permalink)
Turk's Avatar
Find the fuel tank vent line & blow into it(do not suck!!!)
2011 apex xtx
slightly tweaked 03 RX-1
Turk is offline   Reply With Quote
Old 10-15-2008, 11:19 PM   #4 (permalink)
plowking's Avatar
Our rages have done that. Like the felllow said blow into it or make a fiitting to fit gas tank opening and give it some air from the air compressor, to force the fuel up the lines to the pump. plowking
plowking is offline   Reply With Quote
Old 10-16-2008, 05:13 PM   #5 (permalink)
vmaxx05stud's Avatar
so are these rage/vector know for this issue of not keepibng fuel pressure or not starting?
vmaxx05stud is offline   Reply With Quote
Old 10-16-2008, 09:14 PM   #6 (permalink)
plowking's Avatar
so are these rage/vector know for this issue of not keepibng fuel pressure or not starting? [/b]
No, not in the winter with constant use. It happens after being stored for long periods of time without being started. plowking
Old 10-19-2008, 11:16 PM   #7 (permalink)
Find the fuel tank vent line & blow into it(do not suck!!!)[/b]
So that's what "I did, Hick-up" wrong,belch puke hack cough. slurp.........KAA.. BOOOOOOOOOOOOOOOOOm !!!!!!!!!!!!!!!!!!MM.
madmax vector is offline   Reply With Quote
Old 11-20-2008, 07:21 PM   #8 (permalink)
Member
skibumalp's Avatar
Current Sled(s): 08 vector LTX
Previous Sled(s): 02 v-max 700 purple
Favorite Riding Area: upper mich.
Riding Since: 79
Cool
HI My 08 vector does not want to start after sitting all summer. it cranks and cranks and cranks till battery is almost Dead.This is what i have done and it saves lots of problems. I drilled two 3/8 holes [one on each side of air box] in line with the intakes, Installed vinyl plugs in the holes ,when i want to start the engine,in the start of the season remove them and shoot in gas or that no no starting fluid. Starts in 5 seconds with full choke and saves the starter.battery,and other problems. Yamaha Says we dont need to do this,but some of us know better....No more hard starting. Tony
skibumalp is offline   Reply With Quote
Old 12-02-2008, 04:41 PM   #9 (permalink)
Dardevil3's Avatar
Mine did it last year. Like stated above the fuel pumps need fuel in them to prime up. But, not only that, you should put in good fuel. They are very finicky for the first start of the season if you have old crappy gas in them. Get some new premium and get it flowing in there too. Once it burns off that old crap gas it should run like a top.
Just from experience i am guessing it will take 1.21 gigawatts to get that thing back in action... your going to have to go to your dealer and ask for a new flux capacitor!
Dardevil3 is offline   Reply With Quote
Old 12-11-2008, 11:54 PM   #10 (permalink)
veryfast's Avatar
Current Sled(s): yamaha attak
Previous Sled(s): mach z
Favorite Riding Area: nuttby
Riding Since: 86
my yamaha attack does the same thing sometimes, it is the fuel relay it gets moisture in it and it does not send any power to the fuel pump, happens on colder days, ifyou warm up the relay with a hair dryer it will start, but that kinda sucks big time!!!
Yamaha ATTAK is where its at!!!
(Quit staring at MY ladies Tits)
veryfast is offline   Reply With Quote
