05 RX1 OIL CHANGE - HCS Snowmobile Forums
Apex / Vector / Rx1 This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 11-19-2007, 02:10 PM   #1 (permalink)
Newbie
How easy or hard is it to change oil and filter on the rx1? Is it better to bring it to the dealer? Anybody have detailed instructions on how to change oil and filter?
spankyvycrx1 is offline   Reply With Quote
Old 11-19-2007, 06:18 PM   #2 (permalink)
Custom RX1's Avatar
I can tell you how. Take the right side off. You will find an oil can there.On the bottom there is a drain plug. Turn out with a open end. Then under the sled there is a hatch open it. You will see a BIG bolt undo that. Than go to the hood, pull the air box out, than you will see the battery, pull this out. You will see the oil filter.
Custom RX1 is offline   Reply With Quote
Old 11-19-2007, 08:43 PM   #3 (permalink)
nowa's Avatar
Current Sled(s): 2012 Ski Doo 800r E Tec
Favorite Riding Area: NEK Qc.
14-15 Mileage: -0-
13-14 Mileage: 4670
Its pretty simple. Take your time and youll be done in under an hour. Go to Yamaha.com and you can read how to do it right out of the manual. Ive done several oil changes now and it only takes about 25-30 minutes!!
FROM ZERO TO DEAD IN UNDER 1O FEET!!!
nowa is offline   Reply With Quote
Old 11-27-2007, 03:49 PM   #4 (permalink)
Newbie
Post
I can tell you how. Take the right side off. You will find an oil can there.On the bottom there is a drain plug. Turn out with a open end. Then under the sled there is a hatch open it. You will see a BIG bolt undo that. Than go to the hood, pull the air box out, than you will see the battery, pull this out. You will see the oil filter.[/b]
Custom rx1, Those directions were right on, it was as easy as you said, Thyanks!!!
Old 11-27-2007, 03:52 PM   #5 (permalink)
Newbie
Post
Custom rx1, Those directions were right on, it was as easy as you said, Thyanks!!![/b]
