Switchback 600 ho NO SPARK - HCS Snowmobile Forums
IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 11-01-2012, 08:28 AM   #1 (permalink)
Current Sled(s): 07 RMK for now
Previous Sled(s): Indy's, SX's, Srx's, IQcfi,S.B's,12' Pro Ride,Vector,Xc's
Favorite Riding Area: Upper, lower penninsula
Riding Since: 1984
Default Switchback 600 ho NO SPARK
Bought a 2006 switchback this summer with a destroyed water impeller. Sleds been rebuilt from the bottom up. I mean everything...Just put it back together last night and went to fire it up for the first time and "no spark" yeeha.
-Checked all wiring connections
-Tested Stator and specs are dead on
-Plugs are good, pulled them off my gf's running cfi
-Caps are good, pulled them off the cfi as well
-Key's on/kill switch's on
The only history i know is...
-Sled was running down the trail and the temp guage hit 185 degrees so he shut it off. Everything was running before that.
IQ600cf-i is offline   Reply With Quote
Old 11-01-2012, 12:14 PM   #2 (permalink)
crusher139's Avatar
Current Sled(s): 09 D8
Riding Since: 1995
Well there is a good change there is more to that story.
Did you try pulling the plugs out but still attached to the spark boots and touch them to metal and pull the starter. See if there is any spark that way.
Are you sure it is the spark and not anything else. like fuel or your carbs?
crusher139 is offline   Reply With Quote
Old 11-01-2012, 12:43 PM   #3 (permalink)
Riding Since: 1984
Guy was straight forward as can be and really didn't have any reason to lie, pistons/rings/bearing etc...were all still in good shape, so I believe him..
Grounded plugs out, pulled starter, no spark...really looking to see if anyone has dealt with this b4 I ge any deeper....is there a electronic shut off when the motor gets to hot? Possibly the computer needs to be reset?
Old 11-01-2012, 03:28 PM   #4 (permalink)
krss144's Avatar
Current Sled(s): 2000 XC 600 SP, 98 XCR 800 BIG BORE
Previous Sled(s): 02 XC 700-wifes
Favorite Riding Area: UP, Lake Ann, Irons
Riding Since: 1996
HI
99 Banshee w/ go fast goodies!
krss144 is offline   Reply With Quote
Old 11-01-2012, 05:03 PM   #5 (permalink)
Riding Since: 1984
Kurt u got this shit figured out for me yet? Lol
Old 11-01-2012, 09:34 PM   #6 (permalink)
northstarrick's Avatar
how much throttle lever gap? should be about .010. if its to wide it grounds the c.d.i. just like the kill switch does.
Old 11-02-2012, 08:26 AM   #7 (permalink)
Current Sled(s): IQR, IQ
Previous Sled(s): XCR, RMK, XC
Favorite Riding Area: Cooke City, MT
Riding Since: 85
Have you checked the coil? I had one fail on my wifes sled. Was intermittent at first, then went completley dead.
Specs on the coil are:
Black to White .3 Ohms
Black to Secondary Lead: Open
Plug lead to plug Lead: 15K Ohms (15k Ohms is broken up into 5k between leads, 10K for plug caps)
All values +/- 20%
Also try disconnecting the square plug next to the cdi. This will eliminate the kill switch circuit and let you rule that out as a potential point of failure.
Anger890 is offline   Reply With Quote
Old 11-02-2012, 09:07 AM   #8 (permalink)
krss144's Avatar
Riding Since: 1996
Todd we should check what Anger 890 listed. I'll be over tonight and check the coils like I said last night.
Old 11-02-2012, 09:57 AM   #9 (permalink)
Riding Since: 1984
Im guessing they must have changed the routing for the kill switch plug, as there isnt one next to the CDI on this bad boy....but I did find it on the mag side and I had it plugged into the thermostat sensor, and vice versus. Both the same plug, and right next to each other. Re worked those two and BAM all kinds of spark! Now i just need to tune the carbs as its running rich as shit. Also need to replace the Thermostat sensor as it tested out bad...and is giving me an error code. Thanks for the heads up ANGER! and Rick, good advice to have! Would of been too funny if that was the problem. thanks!
Old 11-02-2012, 02:07 PM   #10 (permalink)
Riding Since: 85
Glad to hear you got it figured out. For future reference the kill switch is routed through the MFD connection which is a sqaure plug with a purple center located to the right of the main CDI connection.
Looks like this:
Having volatage going ot the Temp sender may have damaged it as it only designed to read resistance.
Black & Brown Wires = Temp Sender
Black & White Wires= Coil
