time to rebuild? - HCS Snowmobile Forums
IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 02-23-2012, 01:30 PM   #1 (permalink)
Newbie
Current Sled(s): 08 IQ shift 600
Favorite Riding Area: pittsburg
10-11 Mileage: 2500
Riding Since: 2005
Default time to rebuild?
Hello hardcoresledders, I have a 2008 IQ Shift with 6000 miles(hard miles), and I am inspecting the top end. One of my valves has made slight contact with the piston without damage to either, the valve stops in the cylinders are getting quite worn, as are the valves themselves, i have researched this and plan on shaving the valves back, and have ordered updated washers that go between the valve and bellows(i would like to think they are a little thicker to keep the valve off the piston?). the compression is 138psi in both. I am also wondering if any play(slop) in the wrist pins/bearings is tolerable, when i turn the primary from side to side there is some play before the pistons actually move. I have not taken the engine down but i went in with a scope and everything appears to be in good shape. My main question would be is it worth trying to get the rest of the season out of it, probably 500 more miles, or should i tear it down and rebuild?
978alwaysbroken is offline   Reply With Quote
Old 02-23-2012, 02:12 PM   #2 (permalink)
Current Sled(s): 03 edge/xcr
Favorite Riding Area: Michigans Upper Penninsula
Riding Since: 1995
Run it you have plenty of time in the summer to rebuild no use in wasting good riding time!! Like they say it will go or blow either one is fun in its own way!
Michiganstopcat is offline   Reply With Quote
Old 02-23-2012, 03:59 PM   #3 (permalink)
JP33's Avatar
Current Sled(s): 2013 Pro-R6
Previous Sled(s): D8, IQ6, XCSP6
Favorite Riding Area: In The Woods...
12-13 Mileage: 1160
11-12 Mileage: 732
10-11 Mileage: 1538
Riding Since: 85'
With those comp numbers and finding nothing bad during your visual inspection, I would run it and deal with it in the off season. There's not much left anyway.
JP33 is offline   Reply With Quote
Old 02-24-2012, 04:35 PM   #4 (permalink)
shagsmc's Avatar
Current Sled(s): 2008 Switchback 600
Previous Sled(s): 94 Indy Trail 500Fan - 85 Indy 440Fan
Favorite Riding Area: On snow
10-11 Mileage: 14
Riding Since: 1994
I am a little concerned about my 08 600 Switchback, 5000 miles with 200 engine hours. After reading this I'll probably tear into it this summer.
2008 KTM 200 XC-W
shagsmc is offline   Reply With Quote
Old 02-24-2012, 10:30 PM   #5 (permalink)
Can you explain what the washers accomplish? The valve land still sits on the cylinder land.
poo boy is offline   Reply With Quote
Old 02-25-2012, 07:58 AM   #6 (permalink)
fastsleddr's Avatar
Current Sled(s): 09 685 shift / Barney / 06 fuse
Previous Sled(s): Lots of everything
Favorite Riding Area: the bedroom YEEHAW!!
12-13 Mileage: 1930+
11-12 Mileage: 1700+
10-11 Mileage: 1945+
Riding Since: 1968
BIGGEST concern with the 600 HO carbed motor is--the oil pump drive gear on the crank. They like to wear out at about 6000 miles.( I've seen this many times as I've rebuilt many)
I would run it the rest of the season, than tear it ALL THE WAY DOWN. and inspect the crank gear!!
Poo---In my research and engine rebuilding I found a place that drills into the cylinder and installs a stainless steel exhaust valve stop. Can't remember who at this time.
The reason the exhaust valve scuffs the piston is the stop in the cylinder, and the stop on the valve get worn. You can remidy this by grinding some extra clearance on the exhaust valve.
fastsleddr is offline   Reply With Quote
Old 02-25-2012, 09:15 AM   #7 (permalink)
Newbie
10-11 Mileage: 2500
Riding Since: 2005
I will be grinding the valve and running it for the rest of this season. Thanks for the heads up fastsleddr, i have yet to hear that in all my research on my sled, I plan on taking it all the way down this summer, and my hope is that i can 660 her( so long as i can scrape up the $).
Old 02-25-2012, 10:33 AM   #8 (permalink)
Pro R's Avatar
Current Sled(s): 800 Pro R, xc8, jdx6
Previous Sled(s): 700 Dragon, fusion, xcr8, ultra SPX, xcr6sp
Favorite Riding Area: close by
12-13 Mileage: 3003
11-12 Mileage: 971
Riding Since: 1975
kraven on here sent me this last year about a company that does something like you are talking about, here is what he sent me.
IF you're replacing pistons, you may want to talk to MILLENNIUM TECHNOLOGIES about replacing/adding NEW exhaust valve "stops" into your cylinders. Remember the issues with high mileage stops becoming worn and then allowing the exhaust valves to contact the pistons
Pro R is offline   Reply With Quote
Old 02-25-2012, 11:09 AM   #9 (permalink)
fastsleddr's Avatar
Riding Since: 1968
If your a gearhead like me skip the 660 and go 685--I've had both.
The 685 is worth the extra$$$$$
I'm hooked up with makin the 685 kits,AND, the 660's for that matter. Pm me for pricing.
Old 02-25-2012, 03:22 PM   #10 (permalink)
IQPolarice's Avatar
Current Sled(s): '12 Switch Pro-R 600, '10 Shift 600
Previous Sled(s): '07 IQ 600 carb (spare) '99 XCSP 700
Favorite Riding Area: West Hiawatha National Forest
12-13 Mileage: 1200
11-12 Mileage: a lot
10-11 Mileage: 1250
I have an '07 carb with 7500 miles on it. Do you think I should rebuild? I did have an issue at the beginning of the season with both exhaust valves missing about half. That was when we cleaned them from last season.
IQPolarice is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
