gabes OTP helix - HCS Snowmobile Forums
IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 03-11-2011, 10:25 PM   #1 (permalink)
toddur's Avatar
Current Sled(s): 15 RUSH 800 PRO-S
Previous Sled(s): 95 XLT,99 XC500,02 XC500,07 IQ600CFI
Favorite Riding Area: Anywhere there is snow!
15-16 Mileage: 1970
14-15 Mileage: 2480
13-14 Mileage: 2320
Riding Since: 1995
Default gabes OTP helix
I have one of gabes kit for my 07 600 cfi. does anyone know what helix he uses? He grinded off all the numbers.
toddur is online now   Reply With Quote
Old 03-12-2011, 09:42 AM   #2 (permalink)
dynofox's Avatar
Current Sled(s): IQR 600, XRS 800
Previous Sled(s): IQRR, Pro XR 660, D6, Rev 800X, Rev 600X
Riding Since: 1985
I'm sure he'd like to keep those angles private, hard to sell clutch kits with everyone knowing what to buy on their own.
K&H Motor Sports - Wasted Wages Racing
dynofox is offline   Reply With Quote
Old 03-12-2011, 11:41 AM   #3 (permalink)
toddur's Avatar
15-16 Mileage: 1970
14-15 Mileage: 2480
13-14 Mileage: 2320
Riding Since: 1995
Well it was worth asking, i'm sure their is a way to find out.
Old 03-13-2011, 11:23 AM   #4 (permalink)
MR. X's Avatar
MSC Item Detail
Try this out it will get you close enough , if you have a chart with the helix specs you'll be able to figure out which one you have.
MR. X is offline   Reply With Quote
Old 03-14-2011, 01:59 PM   #5 (permalink)
Gabes's Avatar
Current Sled(s): OTP POLARIS!!!
Previous Sled(s): Everything Polaris from TX to Rush.
Favorite Riding Area: Somewhere with snow
Riding Since: 1981
Good luck!!!
Gabes is offline   Reply With Quote
Old 03-14-2011, 05:08 PM   #6 (permalink)
toddur's Avatar
15-16 Mileage: 1970
14-15 Mileage: 2480
13-14 Mileage: 2320
Riding Since: 1995
Originally Posted by Gabes View Post
Good luck!!!
Thanks! No offense but i had the kit in my 07 600 cfi and i can't get it to hold rpms when i get over 70 , so i was going to change my sled over to the 08 clutch set-up which has the same stock springs ( blk/green primary red/blk secondary) but use 64 g weights and a 56/42 -.36 helix instead of the 64/42-.36 helix and 62 g weights that the 07 has , i dont think the 62 grams weights are heavy enough to pull down into the team clutch. so if i knew what angles your helix had i could maybe use it with the 64g weights. But i'm sure you can tell me if it is a completly different helix then the helix that you sell in the kit for the 08 and up 600.
Old 03-14-2011, 06:12 PM   #7 (permalink)
OutKast's Avatar
Current Sled(s): 2017 SBA 800 2015 INDY 800 2015 INDY 550
Previous Sled(s): Couple D8 Rockets
And this is why I do not buy Pre-made clutch kits. There is no way this or other kits will work for the same model sleds right across North America. Piece together your own kit, as you have already been doing and you will get what you want for your style of riding!
2006 AMCRA Amateur Rookie of The Year
2007 AMCRA Amateur Open Sportbike Champion
OutKast is online now   Reply With Quote
Old 03-15-2011, 11:46 AM   #8 (permalink)
Gabes's Avatar
Riding Since: 1981
So, your not holding RPM's and your going to go up in weight?????
Our set up will hold rpm's all day long. I hate to say it, but you have other problems.
We do not use any of the helix's you listed above, so if you want to try on of those it will be different than what we sent you.
Old 03-15-2011, 01:01 PM   #9 (permalink)
toddur's Avatar
15-16 Mileage: 1970
14-15 Mileage: 2480
13-14 Mileage: 2320
Riding Since: 1995
yea go up in weight but down in helix angle. The problem with the sleds rpm are up top on the the swallower angle , it will hold rpms all day down low. And this sled has been gone through up and down, 120 psi comp. both cylinders, exhaust valves good, tps good, reflashed, track loose , ski alignment good, no exhaust leaks , dealer has checked numerous times for any codes-none found, i am running out of ideas , so i figured if polaris is using 64 g weights with that helix it must work, i haven't seen any complaints on the 08 and up 600. Actually the EPI clutch kit uses 64g weights. so its worth a shot. i figure $100.00 for the helix and if it doesn't work i can resell it on e-bay or a swap meet for $ 50.00.
But thanks for your input. Cause you are the first one to tell me i have something else wrong with my sled.
Old 03-15-2011, 01:13 PM   #10 (permalink)
MR. X's Avatar
Good luck!!!
Im sensing some cockyness in your response , perhaps im wrong though.
