Changing the jackshaft bearing in a 2008 IQ 600 - HCS Snowmobile Forums
IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 02-18-2011, 10:49 PM   #1 (permalink)
Banned
Default Changing the jackshaft bearing in a 2008 IQ 600
Can the jackshaft bearing be changed without taking the entire jackshaft out? Any help would be much appreciated. Thanks.
144293 is offline   Reply With Quote
Old 02-19-2011, 01:26 PM   #2 (permalink)
Current Sled(s): 09 SW 800, 09 iq800,04
Previous Sled(s): 04 XC700 01 XCR 800
Favorite Riding Area: Lake Gogebic, Land O'lakes
Riding Since: 77
You need to take it out it's pressed on.
racerx46 is offline   Reply With Quote
Old 02-19-2011, 09:10 PM   #3 (permalink)
Banned
I think the noise my sled was making was from ice. It all melted after the warm up and i can't hear the noise anymore. I feel a lot better about it. Even though there is 5.700 miles on the sled. Should the bearing needed to be replaced by now?
Old 02-19-2011, 11:08 PM   #4 (permalink)
rayone02's Avatar
Current Sled(s): 2012 nytro xtx - 2006 attak
Previous Sled(s): 02 600 - 97 xlt- 2007 600 ho
Favorite Riding Area: U.P.
13-14 Mileage: 1400
Riding Since: 1980
I would change all bearing at that mileage. Last summer I did all drive bearings not that hard to do.
rayone02 is offline   Reply With Quote
Old 02-20-2011, 12:13 AM   #5 (permalink)
Banned
How do i get the jackshaft out?
Old 02-20-2011, 09:54 AM   #6 (permalink)
Riding Since: 77
Just so we are talking about the same one, the Jackshaft is the one by the secondary, not the shaft that runs through the track.
Mine went out at 4500 miles, you should check it.
Pull belt and secondary, see if there is any visible wear. Check for excessive play.
If it's bad pull air box, pipe and silencer. Open chain case and remove chain and top sprocket. Remove 3 bolts holding jackshaft bearing and pull shaft out left side.
Take to someone that has a press and have them swap bearings.
Old 02-21-2011, 05:27 PM   #7 (permalink)
Bames's Avatar
Current Sled(s): 07 Polaris IQ CFI 600
That's the only tricky part, is that they are press fit. I'd recommend changing them at your mileage anyway. If it's not making the noise anymore then it may be because the bearing is gone. And that leaves your jackshaft room to eat up your airbox which turns expensive fast. Something to inspect when you take it out...
2007 Polaris HO IQ CFI 600
Bames is offline   Reply With Quote
Old 02-22-2011, 11:05 AM   #8 (permalink)
Super Moderator
fastsleddr's Avatar
Current Sled(s): 15 AXYS 800/ 09 shift 797/ 06 fuse 600
Previous Sled(s): Lots of everything
Favorite Riding Area: the bedroom YEEHAW!!
16-17 Mileage: 2050+
15-16 Mileage: 2750+
14-15 Mileage: 3408
13-14 Mileage: 2515+
Riding Since: 1968
I change the jackshaft and drive shaft bearings on my shift last summer.
I converted the jackshaft bearing to a greaseable one.
fastsleddr is offline   Reply With Quote
Old 02-18-2013, 01:20 AM   #9 (permalink)
GoneSnowmobilin''s Avatar
Current Sled(s): 2012 800 Pro-R Switchback
Previous Sled(s): 08 Dragon 600 and 97 Ultra SPX
Favorite Riding Area: Anywhere there is snow
16-17 Mileage: 950
15-16 Mileage: 626
14-15 Mileage: 2822
13-14 Mileage: 3325
Riding Since: 1988
I pulled this up on a search. My 2008 dragon just turned 10,000 miles. I've never changed jackshaft bearings or driveshaft bearings. I have a needle grease gun that I can get grease inside the jackshaft and the driveshaft bearings sound fine. Should I still be worried about them?
Second prize is a set of steak knives. Third prize is you're fired.
GoneSnowmobilin' is online now   Reply With Quote
Old 02-18-2013, 02:38 PM   #10 (permalink)
northernshift's Avatar
Current Sled(s): 13 Vector LTX, 08 IQ Shift
Previous Sled(s): Polaris Indy 500,400,440,340,Cutlass SS 440,SkiDoo Blizzard
There's two schools of thought when it comes to bearings.Some guys change their bearings at regular intervals(2-3 years)and others keep checking them regularly and change them only when necessary.I have an 08 shift with 5000 miles,all original.I also have a 96 Indy with 8000 miles and I changed all the wheel bearings this year for the first time (17 years).Out of 11 wheel bearings, 9 were good,1 was rough,1 was shot.I say,check all your bearings 2 times a year and change only when necessary.
northernshift is offline   Reply With Quote
