OTP performance clutch kit - HCS Snowmobile Forums
IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 12-01-2010, 04:42 PM   #1 (permalink)
Banned for life
Current Sled(s): 08 600 Dragon & 02 800 XC
Previous Sled(s): Many
Favorite Riding Area: Chautuaqua & Wyoming Counties
Riding Since: 1988
Default OTP performance clutch kit
so, i have one of these in my dragon 600. the only problem is that it turned my sled into a dog on the low end and i lost about 5 mph top end but it's fast as hell mid-range. that doesn't make up for the huge decrease in performance in other areas. i'm considering putting the OEM parts back in. anybody have any info as to what i could do to fix this problem?
126559 is offline   Reply With Quote
Old 12-01-2010, 05:05 PM   #2 (permalink)
HMMMM....I just installed the same kit on my 08 D6, I havn't had a chance to try it out yet, but Gabes told me I should see improved performance across the board - maybe he will chime in here. What weights are you running? Gabes told me to put in 10-62's which I did.
brianw7 is offline   Reply With Quote
Old 12-01-2010, 05:09 PM   #3 (permalink)
Banned for life
Riding Since: 1988
yeah, i put 10-62's in. when i first tested it out, the sled seemed faster but after a years worth of riding, i was able to determine that it's slower low end. i was able to get the sled up to 103 before the kit and now, i can't get it above 98. take off is so damn unimpressive that it actually pisses me off.
Old 12-01-2010, 07:59 PM   #4 (permalink)
JP33's Avatar
Current Sled(s): Looking....
Previous Sled(s): Axys 8, Pro6, D8, 600HO, XCSP6
If your running the same springs from 2 or 3 seasons ago you need to get new ones asap. It may not be the clutch there are many other possibilties. A friend who is running my old fuse felt it was slowing down last season so we serviced the clutch put fresh springs in as well as finding out his exhaust was leaking in three places!
JP33 is offline   Reply With Quote
Old 12-01-2010, 08:16 PM   #5 (permalink)
Banned for life
Riding Since: 1988
there are 1500 miles on the springs, they shouldn't need to be changed already. i also am running a slp blue/pink clutch spring in the primary instead of the green team spring that gabes sent me. the blue/pink is 140/340 instead of 140/330
Old 12-01-2010, 08:20 PM   #6 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
13-14 Mileage: 1,864
Riding Since: 1959
At 1,500 miles the springs will lose 15-20% full shift tension when compared to new ones.
Old 12-01-2010, 08:25 PM   #7 (permalink)
Banned for life
Riding Since: 1988
that's blows.
Old 12-01-2010, 08:27 PM   #8 (permalink)
Banned for life
Riding Since: 1988
how much of a difference would adding epi belly buster compared to regular polaris clutch weights? would it be worth the money? i would put 10-64's back in with the stock parts.
Old 12-01-2010, 08:27 PM   #9 (permalink)
Super Moderator
XCR1250's Avatar
Riding Since: 1959
that's blows. what ratio would a light purple team secondary spring be? i'm going to by slp springs instead. i like them better.
Springs can be touchy, some aftermarket companies do not check pre-load and fullshift tensions at the same heights as OEM springs. I've had the best luck with OEM, at least you know what you have.
I test all new springs on my Rimac tester, even 2 springs with the same part number will be different between them, almost everytime.
Old 12-01-2010, 08:31 PM   #10 (permalink)
Banned for life
Riding Since: 1988
so are you saying i should stick with the team spring?
