single or dual carbides - HCS Snowmobile Forums
IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 11-27-2010, 02:41 PM   #1 (permalink)
Current Sled(s): 08 D7 and 10 D8
Previous Sled(s): 02 xcsp
Riding Since: 1979
Default single or dual carbides
I have a 2008 Dragon 700 that darts a little. Which would help eliminate this?
Dual carbides or shimming the skis?
1shooter is offline   Reply With Quote
Old 11-27-2010, 02:54 PM   #2 (permalink)
stringcheese's Avatar
Current Sled(s): 06 Firecat 7 efi
Previous Sled(s): 1993 Thundercat
Riding Since: 1980
You compromise cornering doing either. If you are not taking corners around 50+ then get dualies.
stringcheese is offline   Reply With Quote
Old 11-27-2010, 03:04 PM   #3 (permalink)
stormtrooper's Avatar
Current Sled(s): Black sled
Previous Sled(s): red, blue, green, and yellow.
I never liked dualies, they're heavy and I did not find them any better. The dragon should not dart look for other causes.
Last run 04/18/09 130 miles Rogers Lake
Last run 03/20/10 100 miles Albert county, crank went
Last run 04/22/11 83 miles Mount Fronsac
stormtrooper is offline   Reply With Quote
Old 11-27-2010, 04:55 PM   #4 (permalink)
I run woodys slim jims 6" 144 studs on my 800 dragon . Love it corners nice.
700bigblock is offline   Reply With Quote
Old 11-27-2010, 08:49 PM   #5 (permalink)
michahicks's Avatar
Favorite Riding Area: Northern Lower and UP
Riding Since: 1969
Shims affect cornering? I don't think so..... I've never even heard of that claim before.
Confirm your front alignment is right, and try a set of those before spending a lot of money on something else.
The downside to duallies is under some conditions they'll pack snow and ice between them and actually start riding up on whatever they gather between them - lifting the carbide completely up off the surface they should be digging into. Aggressive riders don't/won't use them because of the potential for questionable handling. They work great for guys that mostly cruise.
michahicks is offline   Reply With Quote
Old 11-27-2010, 08:55 PM   #6 (permalink)
Current Sled(s): 2009 GSX 1200 Doo
Previous Sled(s): 700 Fuse, 2007 PooFST
I had duallies on my 700 Fusion and originally on my FST, They make it straight as an arrow but cornered terribly which I didn't mind because I could at least control going INTO the corner. I could not STAND the darting when I let off the throttle. Finally spent the $$$ on Bergstrom triple points ski savers and shims on the FST... It's not the same sled. Absolutely, hands down the way to go as far as I'm concerned. Turns in everything (hard pack, powder, or pavement) and virtually eliminates darting.
sabrecanuck is offline   Reply With Quote
Old 11-27-2010, 09:23 PM   #7 (permalink)
nitrousxc's Avatar
Current Sled(s): 2013 600 Pro R
Previous Sled(s): 10 D6 SB, 09 8 IQ, 08 D7, 06 600 Fuse, 06 Ape-X
Favorite Riding Area: Old Forge
13-14 Mileage: 1100
Riding Since: 1988
I've had duallies before and I feel they're down right dangerous. As stated above they push in the corners. Even worse is sometimes they'll grab and then push making it unpredictable. A sled that skis are properly aligned and possibly shimmed won't dart. Unless it says Yamaha on it!
nitrousxc is offline   Reply With Quote
Old 11-27-2010, 10:48 PM   #8 (permalink)
Current Sled(s): 06 FST Switchback, 11 Assault
Previous Sled(s): Switchback, Race Sleds, Sno Sport/Scoot,
Favorite Riding Area: Northern WI
Riding Since: 1986
I run a Polaris Race ski or you can go with C&A Pro that has a deeper keel and single carbides and that seems to work out good, havent had darting issues.
snorox33 is offline   Reply With Quote
Old 11-28-2010, 02:04 AM   #9 (permalink)
kraven's Avatar
Current Sled(s): 2007 DRAGON 700, 4500 MILES
Previous Sled(s): 2002 EDGE-X 800,6400 miles, 1999 XCR 800
Favorite Riding Area: YELLOWSTONE
Riding Since: 1985
Cool www.bergstromskags.com
Why not give Scott Berstrom a call, real knowledgeable guy to talk to and will steer you in the right direction.
BERSTROM Tripple points and some shims and you'll never want anything else, and save yourself $300 on aftermarket skis.
Byron Circa 1984, '72 Dodge Colt, Full Tube Chassis, Strange Struts, 4 Link, Koni Coil Overs, 15" x 33", Mild 426 Wedge, Torqueflite, Lexan windows, Dzus Fasteners & Quick Release Pins Everywhere, All Polished Aluminum Interior, Fuel Cell, "Weld" Superlite Wheels, 2220 lbs. w/Driver, Leaving the Starting Line Carrying the Front Wheels and Being Plastered into the Back of the Seat and Stopping it from 137+ m.p.h. by Pulling the Parachute-PRICELESS!!!
Byron, 1982, 71 Dodge Demon, 426 Wedge, Aluminum 4-speed, Narrowed Dana 4.56, Alston Bars & Floater, SS Springs, 12.20" x 31.25" Firestones, Polished Centerlines, 10 pt Rollcage, Aluminum wheel tubs, Fiberglass fenders, hood, & decklid
1986 INDY 600 LIMITED EDITION CHROME PACKAGE [/b]91 M.P.H. @ RADAR RUNS 1000' (6000+ MILES) TRAILERED TO YELLOWSTONE IN 1988
kraven is offline   Reply With Quote
Old 11-28-2010, 03:50 AM   #10 (permalink)
Oh $h!T, I setteled on ATS Arrow ski's cause I did'n't want to spend the extra $ on Pilot 5.7'.s. I hope they'll be alrght.
Gone Fishing !
Freakbrother69 is offline   Reply With Quote
