| IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#11 (permalink) |
Member
Current Sled(s): 2012 Pro-R800
Previous Sled(s): 2010 RMK, 2008 SB, 2006 SB, 2002 RMK, 2000 RMK, 98 XC, 96 Ul
10-11 Mileage: 1400
Wayne,
Tested your stock map Sunday, -8 at testing time, 800 RMK 144, Cobra 1.38, 68 Gram polaris. 8100-8150 RPM, det light issue 6000-7500 on and off, 101 MPH easy in semi hard pack in short run, 1050-1150 mid, 1200-1250 WOT. Plugs black, ran much better than stock, will be taking your advise and removing from bottom and adding a little at 80%, this sled is now fun to drive. Thanks! I had a chance to put on some miles this past weekend and had my det light coming on when stabbling the throttle. The light came on between 6500-7500 rpm. If you are running some version of my map and are having this problem, change all of your numbers to 0 or +5 in that whole rpm range. Also, if you have big negatives at 80% throttle from 7500-8500 rpm, you might want to back those down to -5 at the most. You probably can leave the 100% negatives alone...unless you are getting det light. Additionally, you may be able to back down the high positives in the lower rpm range and see how it runs. If you don't get any stumble there, maybe your mileage will improve slightly. I got about 10-10.5 MPG this past weekend but wasn't really hammering it much except on the lakes. Wayne |
| Sponsored Links | |||
Advertisement | |||
#12 (permalink) | |
Super Moderator
Current Sled(s): '11 Polaris SB Assualt & '05 Classic 600
Previous Sled(s): All Polaris and two Yamaha.
Favorite Riding Area: Wherever it is deep!
12-13 Mileage: Who cares?
11-12 Mileage: No idea.
10-11 Mileage: Some.
Riding Since: 1984
because all I can get is E10 fuel here. Not one flicker of det in multiple good half mile pulls on the lake. Lake is glare ice with 4" of powder on it, 0*F temps without windchill. In those conditions it will flash 8400 out of the hole and then pull back to 8200-8250 on the nose. Semi-hard pack reads 8200-8250 everytime. This freakin thing lights like a switch now! No more laying down upstairs, love it! Never pulled it for mph but I can tell ya this, 55-95 is one hard ass pull that takes little time to accomplish if you can hook this biotch up!
#13 (permalink) |
Member
Stoutner I have been using your map that I got from Jim and its works great. I have a question about the PCV, I plugged in the PCV to my laptop and the tps was working fine when I started it up and ran it a bit but then I set up the TPS setting and now when the sled is off the TPS says 100% and when i start it up it goes to zero and stays there did I change something I didn't notice I'm not sure. Any help would be great thanks for all your hard work by the way.
#14 (permalink) | |
Start engine Power Commander Tools>Configure>TPS (Ctrl T) Hit Reset - the idle TPS is now set Actuate the throttle to WOT - you don't have to hold it for any length of time for he setting to "take", just make sure the flipper hits the handlebar. You should now see 4.1x or so volts in the RH box. Click OK, do not hit Reset. You're done. Here is the online page: maneuver to Working with Commander V>Power Commander Tools>To Calibrate the Throttle Position PC V Online Help |
#15 (permalink) | |
Current Sled(s): 2012 Rush 800
Previous Sled(s): '12 '11 Rush 800, '10 FST, '09 D8, '08 D7, '07 Apex
Favorite Riding Area: Anywhere, Ontario
11-12 Mileage: 3000
10-11 Mileage: 2500
Riding Since: 1988
Thanks |
#16 (permalink) | |
Favorite Riding Area: Vilas Co. Wisconsin
http://www.ilsnowmobile.com/Clubs/ivwsc.htm 2012 gearing chart 2http://s234.photobucket.com/albums/ee316/kawidave1/?action=view¤t=switchbackgears2.jpg |
#17 (permalink) |
Current Sled(s): 2009 D8 - Doo and Cat Killer
12-13 Mileage: 175
Wayne I got the 162HP map from Jims site. I have no stumble or ever had any stumble. It is very rich in the midrange. I have the SLP Pipe. Jim told me that I can decrease those #'s by almost half. I am wondering about the top end #'s...should I leave them alone?
I am only at 1500' Elevation max. Thanks.
2006 AMCRA Amateur Rookie of The Year 2007 AMCRA Amateur Open Sportbike Champion
#19 (permalink) | |
Shell Guy....Someone on here should be able to e-mail you the map. I will be out of town for the next 8 days so I won't be of any help until I get back. Oh Snow...If you can't raise your track in the air, just take your belt off and do it. Or, just set it manually for .930 and 4.10 |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
