IQ 800 clutch weights?? - HCS Snowmobile Forums
IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 10-30-2009, 01:36 PM   #1 (permalink)
Brand loyal, not brand blind
racerdave's Avatar
Current Sled(s): 2015 AXYS SWB800 Pro S 2015 Indy 600sp
Favorite Riding Area: Vilas Co. Wisconsin
16-17 Mileage: 1,000
15-16 Mileage: 900
14-15 Mileage: 1900
13-14 Mileage: 1704
Riding Since: 1975
2010 shows 10-68 still stock. Should I have a set of 70's and 72's on hand?
Axys gear chart:
racerdave is offline   Reply With Quote
Old 10-30-2009, 01:59 PM   #2 (permalink)
JP33's Avatar
Current Sled(s): Looking....
Previous Sled(s): Axys 8, Pro6, D8, 600HO, XCSP6
I have a set of stock poo 10-68's and 10-70's if you want 'em. I put in a set of Billet 68's with my clutching changes. The 70's have one ride on them.
JP33 is offline   Reply With Quote
Old 10-30-2009, 02:01 PM   #3 (permalink)
HEMI's Avatar
Current Sled(s): 16 pro x 800 e-start snocheck model
Previous Sled(s): POLARIS,CAT AND DOO
Favorite Riding Area: VERMONT
16-17 Mileage: 2650
15-16 Mileage: 1550
14-15 Mileage: 3250
13-14 Mileage: 2800
Riding Since: 1980
My buddy up in VT just picked up his 2010 cfr 800 ho,it only has 71 gram weights stock,06 f7 efi sno pros had 75 grams stock?Does your new sled only come with two rear idlers like the shift,i saw a pick of a 2010 iq 600 and it was just like a shift.HEMI
HEMI is offline   Reply With Quote
Old 10-30-2009, 05:31 PM   #4 (permalink)
Talking
2010 shows 10-68 still stock. Should I have a set of 70's and 72's on hand?[/b]
I have 09 IQ had 10-68 ran great. Put a Bikeman pipe on and ended up with 71 mxt with 1 gram rivet inside whole, this thing runs very good! Unless you mod your sled check your RPM's. Sled should be clutched at 8200. If that is where it is running ride it like you stole it.
fish809 is offline   Reply With Quote
Old 10-30-2009, 06:35 PM   #5 (permalink)
Current Sled(s): 2012 F1100 Turbo, 2013 F800 RR
13-14 Mileage: 2000
My buddy up in VT just picked up his 2010 cfr 800 ho,it only has 71 gram weights stock,06 f7 efi sno pros had 75 grams stock?Does your new sled only come with two rear idlers like the shift,i saw a pick of a 2010 iq 600 and it was just like a shift.HEMI[/b]
Keep in mind you can't compare two different types or shapes of weight to each other. The actual shift out force generated by the weight has everything to do with where the center of mass is on the weight relative to the pivot. That is why two different weights could end up with similar max rpm, but they will shift out very differently. I have no idea if the weights you mention above are the same type of weight or not but this is a possible explanation.
cfunk is offline   Reply With Quote
