latest oil pump adjustment from polaris - HCS Snowmobile Forums
IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 12-19-2007, 10:08 AM   #1 (permalink)
Current Sled(s): 2015 pro s rush 600
As of bulletin #s-07-10 The oil pump needs to be set 1 line width above the oil pumps index mark. Making this adjustment will bring the ratio to 80:1 This is only for the 07 600 cfi. I have a copy of the complete bulletin from my dealer. Lets get these sleds correct and just ride without worry. Anyone needing help with this technical adjustment E-mail me directly. markshop@wi.rr.com
markshop is offline   Reply With Quote
Old 12-19-2007, 10:31 AM   #2 (permalink)
golfer's Avatar
As of bulletin #s-07-10 The oil pump needs to be set 1 line width above the oil pumps index mark. Making this adjustment will bring the ratio to 80:1 This is only for the 07 600 cfi. I have a copy of the complete bulletin from my dealer. Lets get these sleds correct and just ride without worry. Anyone needing help with this technical adjustment E-mail me directly. markshop@wi.rr.com[/b]
Where did you come up with the 80:1 figure? I just had mine done, and am at 35:1...
Having a cottage in Paradise is paradise.
golfer is offline   Reply With Quote
Old 12-19-2007, 11:09 AM   #3 (permalink)
f7 possum's Avatar
Current Sled(s): poo 2016 sks 800
Previous Sled(s): 09 CF800SP,Poo IQR6, Dragon 7, 3 Fcat
Favorite Riding Area: My cabin, Mancelona
16-17 Mileage: 75
15-16 Mileage: 11,211
14-15 Mileage: 3
13-14 Mileage: 2
Riding Since: ??
Post that bulliten on here.
Later Possum,
TEAM HIGH TEK REDNECK
f7 possum is online now   Reply With Quote
Old 12-19-2007, 11:27 AM   #4 (permalink)
Where did you come up with the 80:1 figure? I just had mine done, and am at 35:1...[/b]
It says it right on the bulletin sheet s-07-10 Its part of the reflash bulletin.
Old 12-19-2007, 11:35 AM   #5 (permalink)
rich03sks700's Avatar
Current Sled(s): 2014 800 Pro R Rush
Previous Sled(s): 2012 600ProR SB, 2011 Rush 800, 09 600 SB, 07 D7, 03 700 SKS
Favorite Riding Area: NE Wis
15-16 Mileage: 700
14-15 Mileage: 1000
13-14 Mileage: 1262
Riding Since: 1969
Polaris injection oil pump efficiency varies greatly, some that are set on the oil pump index pump mark will pump 16 oz of oil in 100 miles, some pump 32 oz & some pump 9.1 oz in 100 miles.
That is why if one just uses fuel to oil ratios when gas MPG varies greatly, oil usage per 100 miles varies greatly!
The Polaris 2000 500cc XC engine's oil pump was very efficient or too large of capacity. So then we usually had to bend the cable mtg bracket down on the oil pump to reduce oil flow to acceptable levels!
Talked to a Ski-Doo owner (since 2001) last week that is still very upset about his old oil guzzling & gas guzzling 2000 Poo 500cc XC. My brother had bent the oil pump cable mounting bracket bent down as far as possible for the owner in 2000, still oil guzzling POS since 2000!!! A Poo dealer would do nothing, so he lost a good customer that still tells a lot of people in his bar that Poos are oil & gas guzzling pieces of shit.
For easy riding I like my sleds to use 70:1 fuel to oil ratios, at 15 MPG = 12 oz oil in 100 miles. Hard riding poor 5 oz of Red Line oil into fuel tank
For hard riding I like my sleds to use 50:1 fuel to oil ratios, at 15 MPG = 17 oz oil in 100 miles.
We use Red Line oil, not Poo Shit VESSSSII Gold Shitttttt!!!
Safe sledding; Rich
rich03sks700 is offline   Reply With Quote
Old 12-19-2007, 05:33 PM   #6 (permalink)
Where should the oil ratio be set on an 2008 700 IQ. Is there a bulletin out on this yet? My Poo dealer refused to change mine and said I would burn the motor if I changed ratio. I am currently about 40:1 after 650 miles.
tico is offline   Reply With Quote
Old 12-19-2007, 06:10 PM   #7 (permalink)
vinceostapowich's Avatar
Where should the oil ratio be set on an 2008 700 IQ. Is there a bulletin out on this yet? My Poo dealer refused to change mine and said I would burn the motor if I changed ratio. I am currently about 40:1 after 650 miles.[/b]
The Bulletin is for 07 owners.
It'll take another year to pull the pooch out of yours. lol!
vinceostapowich is offline   Reply With Quote
Old 12-20-2007, 02:27 AM   #8 (permalink)
It says it right on the bulletin sheet s-07-10 Its part of the reflash bulletin.[/b]
Why are you saying things like this?
The sled does not know whether you are riding easy or hard. The oil pump runs according to how much you hit the throttle. Whether you ride hard or easy the ratio WILL be the same. If you get 15 MPG riding hard you burn the same amount of oil as you would if you get 15 MPG gallone riding easy, if your ratio is the same. And your ratio cant change just because you ride easy or hard... unless, you still ride the factory setting of the IQ oil pumps.
At least on the 600 ho, I have done an adjustment myself, and not just the adjustment to make the throttle plates open at the same time the pump moves, But to actually get the pump set so it doesnt rest on the the motor mount at idle. Yes the 600 cfi rested on the motor mount at idle. That is all that stopped it from closing even more.
600hocfi is offline   Reply With Quote
Old 12-21-2007, 12:00 AM   #9 (permalink)
Current Sled(s): 2011 pro r 800
Previous Sled(s): 10 rush 600, 06 fuse 900, 05 fuse 900
Favorite Riding Area: Northern Wis, UP
Riding Since: 1987
The bulletin actually states the new setting is 80:1 at idle, was over 100:1 with original bulletin specs. 50:1 to 60:1 average is where I would want a 600 set for long term engine life. That would give you approx 300 miles before actually needing oil (light comes on early then needed on most models).
mxr345 is offline   Reply With Quote
