Big boy springs rubbing - Page 2 - HCS Snowmobile Forums
IQ chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 11-23-2007, 03:59 PM   #11 (permalink)
sledge8's Avatar
The new mounting bolt and bushing is basicly the ones they used on the edge sleds. The bushing has the threads in it so there is no nut sticking out. You will need the thin 7/8 wrench as in the past. Just put some in a couple weeks ago.
sledge8 is offline   Reply With Quote
Old 11-23-2007, 04:59 PM   #12 (permalink)
The new mounting bolt and bushing is basicly the ones they used on the edge sleds. The bushing has the threads in it so there is no nut sticking out. You will need the thin 7/8 wrench as in the past. Just put some in a couple weeks ago.[/b]
These are the part numbers for both the 900 and 600 fusion since they are the same chassis
I just had to do the same thing with my 06 600HO. Here is the parts list with numbers
THis is a snow team tips from polaris.
Quant Description Part Number
2 Shaft arm 5132972
2 Screw 7517917
2 Thrust Washer 7555945
2 Lock washer 7552614
rwj1968 is offline   Reply With Quote
Old 11-24-2007, 12:48 PM   #13 (permalink)
Current Sled(s): F8 snopro ext 2011
Previous Sled(s): warrior,tf, fusion 900, switchback 900, renegade x 600 sdi
Riding Since: 2004
Ok and tanks for the help.
7043079-067 Spring, Torsion, 12.5, .359, Black, LH [Std.] 1
19 7043080-067 Spring, Torsion, 12.5, .359, Black, RH [Std.] 1
19 7043130-067 Spring, Torsion, 11.25, .359, Black, LH [Opt]
19 7043131-067 Spring, Torsion, 11.25, .359, Black, RH [Opt]
19 7043128-067 Spring, Torsion, 16.25, .405, Black, LH [Opt]
19 7043129-067 Spring, Torsion, 16.25, .405, Black, RH [Opt]
i could only find this springs. looks like 16,25 is the highest. what do 16.25.405 means?.
or is there other springs to find.
Polaris switchback 900 2006. Team 719 helix, SLP Hot Air Elimination Kits, SLP's MTX Clutch Weights, Timbersled Air Box kit, SLP POWDER PRO SKI.
driv is offline   Reply With Quote
Old 11-25-2007, 12:26 PM   #14 (permalink)
or is there other springs to find.[/b]
These are the ones I installed on my 06 600ho. they work great seeing that I weight 235lbs.
The 16.25 is lbs/inch I think.
They are really heavy duty springs. I set my on the lightest setting and its sits good with me sitting on it.
Old 11-25-2007, 03:06 PM   #15 (permalink)
Riding Since: 2004
Tanx. will order it now. It is hard to install the springs ?
Old 11-25-2007, 04:16 PM   #16 (permalink)
Tanx. will order it now. It is hard to install the springs ?[/b]
Install isn't bad, but I've had the suspension out of my sled several times before. It's always best if you can have someone help you especially when you get to putting the rear bolts back in. You only need to remove the rear suspension-to-chassis bolts (one on each side) to replace the springs.
j45p3r is offline   Reply With Quote
Old 11-25-2007, 04:17 PM   #17 (permalink)
Here is what I would do to install new springs
1 Raise the back of the sled off the ground. Make sure sled is about a 1ft off the gound.
2 Remove the rear bolts.
3 Skid should pivot on front bolts allowing the rear to drop down.
4 Take tension off the springs by removing the long arm from the spring block. Let it hang down on the track.
5 Remove mounting arm on torsion arm. This is splined and should slid off with a little help.
6 Springs should slide off. Note the new springs will look huge compared to new larger springs.
7 New springs should slide on. Note there is a right side spring and a left side spring.
8 Reinstall mount arm on torsion shaft. Splined.
9 Use a jack under the track to lift the skid into position to start bolts. Make sure to use Lock Tite.
10 place prings arms into blocks.
Done.
Hope this helps.
Old 01-12-2008, 02:15 PM   #18 (permalink)
Member
Unhappy
Upgrading these springs will obviously help the rear suspension from bottoming out. Has anyone upgraded the shocks? I just purchased a 08 IQ Shift and they installed the 11# springs on this sled which is to light for a guy like me (250 Lbs). If I hit the bumps hard I get her to bottom out often.
I have read this whole post and want to know would you all recommend I upgrade to the 12.5# or 16.25# springs? Do they have ride weight ranges? I would like a stiffer rear suspension however it would be nice to be able to soften it up if I was going on long trail rides. Will the 16.25# be to stiff? Also the 16.25# springs are not offered on the parts list for the IQ Shift as an option will they still work. I did notice they are not offered on the 06 600 HO either and it sounds like someone is using them on that sled.
Along with the weak springs they also put Ryde FX MPV shocks in the rear. What effect might I expect with upgrading the shocks? Will this help with the bottoming out? The current shocks are not adjustable and I am thinking if I can get to an adjustable shock that might help me get a little stiffer ride. If I do this I might be able to get by with the 12.5# springs and run the shocks a little stiffer????
Any help would be appreciated.
Thanks
zdm123 is offline   Reply With Quote
Old 01-17-2008, 06:06 PM   #19 (permalink)
Riding Since: 2004
thanx for the help. I have put my new spring on, But my rear shock is broken. it is a Walker Evens shock adjustable. it is now pressure when i start to push it. half down it start to get some pressure on. so i think it is broken. is it oil or gas on this shock.
there is no spring on the rear shock.
is this shock good or should i try a difrent shock. ryd or řhlins.
Old 02-19-2008, 04:09 AM   #20 (permalink)
Riding Since: 2004
Will this parts also fit on a polaris switchback 900 2006 ?
