How do you adjust the carburetor in a 1988 yamaha exciter - HCS Snowmobile Forums
Yamaha General Discussion This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. This is a 100% NO BASH ZONE. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. Posting private messages from Members or Site Staff is against site rules and will be subject to banning from site temporarily or permanently.
Old 09-30-2007, 03:50 PM   #1 (permalink)
Newbie
Just aquired a yamaha exciter 1988 sled. It will not stay running when you give it gas. they have not been running in a couple of years. How do you adjust the carb and could it be another problem?
J Kollecker is offline   Reply With Quote
Old 10-01-2007, 08:37 PM   #2 (permalink)
Newbie
Have you cleaned the carbs out? Also check the fuel pump (its under the airbox). If they previous owner did not drain the fuel tank it will gum them right up. Take both the main and pilot jets out of the carbs and make sure they are clean and have no blockages. Once the carbs are back in start it on one cylinder at a time (remove 1 spark plug wire) and use the idle adjustment screw ( screw with knobby handle on the right side of the carb if you sitting on the seat) to correct the idle. Screw it in or out to get the engine to idle at 1100-1300 rpm. each cylinder is idling right, you may have to mess with the idle mixture screws, i don't know the specs on them so if its not on the inside of the hood or drive belt cover you'll have to look it up in a manual.
LukeWilson is offline   Reply With Quote
Old 10-06-2007, 02:03 PM   #3 (permalink)
FreezerBurnt's Avatar
Current Sled(s): 07 Switchback 600 CFI
Previous Sled(s): XCR 600
Favorite Riding Area: NW of Sudbury
Riding Since: 76
one yr carb type in that sled
good reason they change them the next year
FreezerBurnt is offline   Reply With Quote
