Need help adding electric start to Enticer - HCS Snowmobile Forums
Yamaha General Discussion This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. This is a 100% NO BASH ZONE. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. Posting private messages from Members or Site Staff is against site rules and will be subject to banning from site temporarily or permanently.
Old 12-29-2016, 10:49 AM   #1 (permalink)
Member
Default Need help adding electric start to Enticer
I just picked up a 1992 Enticer 2 that does not have an electric starter and I want to add it.
I was actually a little surprised it didnít have e-start. There was a factory option to add the starter and I was hoping to find a detailed parts list, but so far I havenít had any luck locating such a list. Iíve only been able to find the optional kit # 89X-W8180-00-00.
Looking at my í92 Phazerís e-start system as a guide, Iíve come up with the most obvious parts Iíll need:
  • 1. Starter motor
  • 2. Battery
  • 3. Battery tray (I can probably make this myself)
  • 4. Solenoid
  • 5. Ignition switch
  • 6. Harness and/or misc. wiring (I can probably make these too)
Parts I may need:
? Rectifier/regulator? Will I need a different one, or will the one it has work?
? Ballast resistor?
Beyond these parts, Iím not sure, so I wanted to ask someone who knows more about this so I donít miss anything or buy parts I donít need. I hope I donít have to add or change engine parts like flywheel or such?
____
I was also thinking of a slightly cheaper way:
Keep the original (manual) ignition switch and install a push-button & relay to activate the starter. This would save from having to buy a different ignition switch.
As far as the solenoid, I may have an automotive style one. I donít see any reason why I couldnít use any 12v automotive solenoid so long as I can bolt it down somewhere? A used Yamaha solenoid isnít terribly expensive, but why not save a little scratch where I can?
The charging system is the part I wonít cobble together. I want to keep this as close to factory as possible so I donít fry something down the line.
Ultimately finding the factory parts would always be best and the least headaches; however, finding all those parts is one thingÖ and finding them cheap, can be quite another!
Thanks,
StankyJeans is offline   Reply With Quote
