Sled keeps bogging out. - HCS Snowmobile Forums
Old 10-11-2011, 10:48 PM   #1 (permalink)
Member
snowmobilerider101's Avatar
Default Sled keeps bogging out.
This Is for a 1992 Polaris 500 SP EFI so first let me say the carbs wont be the problem because Its a EFI. Well then heres my problem last year when I was riding about thirty mph the sled would start bogging alot and when I gave It gas It would keep on bogging until It went to zero mph but when I gave It gas It would bearly move and all It would constantly do would sit there and bog as If It couldnt move and kept bogging. Well the only time It wouldnt bog was when I was going about sixty then It would ride normal. But If I went under that then the sled would sit and bog every second and wouldnt let me drive for ****. I replaced the plugs but the problem was still there It would Just sit and bog when I would try to give the sled gas and when I was riding would bog down to zero mph Idk wht the problem Is then when I was at zero and I did give It gas It would sit and bog. Then.
snowmobilerider101 is offline   Reply With Quote
Old 10-11-2011, 11:09 PM   #2 (permalink)
Indy-500's Avatar
Current Sled(s): 16 AXYS Pro RMK 800 LE 155"
Favorite Riding Area: The 906!
I think I know the problem. You need to pay attention in english class.
Indy-500 is offline   Reply With Quote
Old 10-11-2011, 11:17 PM   #3 (permalink)
Member
Oh shut up I actually get good grades In english.
Old 10-12-2011, 08:00 AM   #4 (permalink)
michahicks's Avatar
Favorite Riding Area: Northern Lower and UP
Riding Since: 1969
It sounds like it might be running on one cylinder? Have you replaced the plugs? Checked to see if one is running much darker/wetter than the other?
It might also be clutching. If one of the clutch springs is broken the clutching might be unable to keep the engine in the power band it's designed to run in. That might let it shift out too quickly, kind of like taking off in high gear with a car - gutless....
If that's not enough to make you wonder, it could also be a fuel problem.
Point here is it could be many different things. If you want to proceed on your own without throwing a bunch of time, money and parts at it without rhyme or reason, you need to find some information regarding maintenance and troubleshooting and start studying.
michahicks is offline   Reply With Quote
Old 10-12-2011, 10:43 AM   #5 (permalink)
lkoury's Avatar
Current Sled(s): '15 Pro S 800
Previous Sled(s): "14 Pro R 8 12 Pro-R 8, Fried Dragon SP 800, conFusion 900
Favorite Riding Area: St. Donat, Quebec
16-17 Mileage: 2900
15-16 Mileage: 2600
14-15 Mileage: 2900
13-14 Mileage: 3050
Riding Since: 2003
Too funny, but give the kid a break...he needs some help with his sled......and yes, nobody in high school can write anymore....all they do is text each other in abbreviations.
lkoury is offline   Reply With Quote
Old 10-12-2011, 03:16 PM   #6 (permalink)
Favorite Riding Area: Ma.
15-16 Mileage: Zero
14-15 Mileage: not much
Riding Since: 70 s
X2..you need to narrow the field from a fuel problem, electrical or clutching. First be sure your battery voltage is right up there. Any lower than 11v and these sleds do weird stuff. If you haven't replace either clutch spring in a long time ....change them. Inspect the secondary clutch for worn buttons and any sloppy operation. Same with the primary clutch...worn pins, rollers, buttons with contribute to erratic operation.
Old 10-12-2011, 04:18 PM   #7 (permalink)
Member
The sled has 1500 miles so Idk If a clutch would be bad yet but Its a possibility. Maybe It was to hot out because of the coolant coming out all over. But Idk. How would I check the fuel.
Old 11-17-2011, 10:04 PM   #8 (permalink)
F7 Rookie's Avatar
Current Sled(s): 03 F-8 Sabercat EFI Sno-Pro
Favorite Riding Area: u.p.
Riding Since: 1974
did you resolve the issue yet,?
F7 Rookie is offline   Reply With Quote
Old 11-17-2011, 10:51 PM   #9 (permalink)
rabbi's Avatar
Current Sled(s): 2016 600 Switcback Adventure
Previous Sled(s): Lots of Polaris'
Favorite Riding Area: Wi northwoods
15-16 Mileage: 880
14-15 Mileage: 650
13-14 Mileage: 2550
Riding Since: 1979
Another basic check is to check compression. A worn engine will bog on takeoff.
Riding an AXYS, pure adrenalin!
rabbi is offline   Reply With Quote
Old 11-18-2011, 05:49 AM   #10 (permalink)
mjm650's Avatar
Current Sled(s): 97 mxz583
Riding Since: 1990
i have 650 rxl efi and would agree to check battery and clutches mines used to bog everynow and then especially during take-off i replaced all clutch parts and seems to b a little better good luck.
mjm650 is offline   Reply With Quote
