1997 Indy 500 - Efi/Carb Build and conversion - HCS Snowmobile Forums
Old 10-05-2011, 04:01 PM   #1 (permalink)
Newbie
Default 1997 Indy 500 - Efi/Carb Build and conversion
Im trying to rebuild the engine in my 1997 indy 500 (carb) with a limited budget. Ive managed to find someone locally who has a 500 efi motor for sale in my budget. Would i be able to switch the cylinders on the efi motor with the ones i have for my Carbed machine then change the fuel pump to the impulse style and have it run properly? Is there anything else i need to take into consideration when doing this? Any input or suggestions will help
Thanks
Brandon112233 is offline   Reply With Quote
Old 10-05-2011, 08:21 PM   #2 (permalink)
Current Sled(s): CBR 600 Indy
Favorite Riding Area: Meaford and District
hey brandon. its troy. the local guy with the engine. i was running this engine on carbs already so i have everything you need. basically you need the carb spacers i have to make the 34mm carbs fit the 46mm throttle body boots on the motor and the impulse line drilled out which is already done to this motor. since you have a carbed sled already you should have everything else you need. i called you tonight and left a message so give me a shout when you can.
CBR600Indy is offline   Reply With Quote
Old 10-06-2011, 04:37 PM   #3 (permalink)
Favorite Riding Area: Ma.
15-16 Mileage: Zero
14-15 Mileage: not much
Riding Since: 70 s
Actually you want a set of flanges and 38mm carbs with those efi cylinders. They make a little more hp.
Old 10-06-2011, 05:04 PM   #4 (permalink)
ewaustin's Avatar
Current Sled(s): '96 XCR440SP
Previous Sled(s): '96 Indy 500, '85 Indy 400
Riding Since: 2010
where did the 34mm carbs come from? The '97 Indy 500 carb had 38mm carbs from the factory...
ewaustin is offline   Reply With Quote
Old 10-07-2011, 12:16 AM   #5 (permalink)
1998polarisxc700's Avatar
Current Sled(s): 98 XC 700
Previous Sled(s): 68 moto-ski zephyr 372, 95 indy lite
Favorite Riding Area: Sandilands Provincial Forest
15-16 Mileage: 1036
14-15 Mileage: 700
13-14 Mileage: 1500
Riding Since: 2001
Dont the efi engines have bigger intake ports? I would say go with 38mm carbs. More power
Winter:
1998 XC 700 - 220 cylinders, 121" cobra, 10-64's, r12
Summer:
1983 Suzuki GS1100L - stock
1991 Trail Boss 250 - Cyclone cylinder and pipe, 57mph on GPS - out of gear but still pulling
1998polarisxc700 is offline   Reply With Quote
Old 10-10-2011, 03:03 AM   #6 (permalink)
FreezerBurnt's Avatar
Current Sled(s): 07 Switchback 600 CFI
Previous Sled(s): XCR 600
Favorite Riding Area: NW of Sudbury
Riding Since: 76
Some Indy 500 Classics had 34mm carbs btw
FreezerBurnt is offline   Reply With Quote
Old 10-10-2011, 04:47 AM   #7 (permalink)
D-rail's Avatar
Current Sled(s): 2016 AXYS 800 Rush Pro S
Previous Sled(s): Polaris, Ski-Doo, Yamadog, Rupp, G-Whiz, Scrap Iron, etc.
Favorite Riding Area: roller coaster stuff
16-17 Mileage: 995
15-16 Mileage: 3339
14-15 Mileage: 2385
13-14 Mileage: 3900
Riding Since: 1973
About 7 years ago, I did a similar swap on my '93 EFI Indy 500, I kept the bigger (46mm) boots on the cylinder, and cut/shaved the boots from the 38mm carbs to fit inside the bigger ones on the engine. I used Yamabond #4 sealant, and hose clamped them down.. Then, to match the airbox, I cut the airhorns off the throttle bodies, dremeled them out a tad to make them lightly press fit over the carb inlet "bell" and sealed them on. Still runs good, gets 15 mpg.
Men have feelings, too. For example, sometimes we feel hungry.. Now go make me a sammich!
D-rail is online now   Reply With Quote
