help with bog off idle - HCS Snowmobile Forums
Old 02-06-2011, 08:40 PM   #1 (permalink)
Member
awames76's Avatar
Current Sled(s): 1996 indy 500
Previous Sled(s): 1988 arctic cougar 500
Favorite Riding Area: anywhere
Default help with bog off idle
i just got a 96 indy 500 carb ive got the af screw at 1 turn [sticker says 1 turn] tryed from 1/2 to 1 1/2, pilot jet 40 main 290, plugs look good,
comming off idle around 1800 [ says 1600 +- 200] it wont rev have to feather the throttle to get it to rev, ive cleaned the carbs one at a time, if its above 2500 itll rev fine, it just wont rev or really boggy, any ideas what needs to be done to get it to work right,
also the primary kicks in at 3500 is that correct. if not how do i change it new weights. i dont know if anything was done to the clutch.
1996 polaris indy 500
1988 arctic cat cougar 500 blown engine for sale
2003 660 tire kit, lift kit, big bore kit [mine]
2010 yamaha grizzly 450 stock with plow [wifes]
china 49cc 4 wheeler for son [7 yr old]
electric 4 wheeler for son [4 yr old]
nothing for the new born girl yet
awames76 is offline   Reply With Quote
Old 02-06-2011, 10:05 PM   #2 (permalink)
ridin' again?'s Avatar
Current Sled(s): Shopping around
Previous Sled(s): to many to list
Riding Since: 1977
Air screws typically closer to 1 1/2 in my experience witht them. Also, if it is warmer out- 30's like it's been here-it will be boggy. Nature of the beast without jetting down and going farther out on the air screws. I also like to set the idle up closer to 2000 on them to help avoid it.
ridin' again? is offline   Reply With Quote
Old 02-06-2011, 11:22 PM   #3 (permalink)
Member
awames76's Avatar
ok thankyou, i was thinking i changed the ign coil because it was bad how do u set timming , i seen the hole and the marks on the flywheel but at what rpm and what marks, i reused the plate and just changed the coil and replaced it as close as i could but i got the sled as a non runner so i dont know how it was before, i think it might be set retarded???
Old 02-06-2011, 11:37 PM   #4 (permalink)
Riding Since: 1977
Timing should be 28* +/- 1.5 at 3000RPM. Check it with a timing light just like a car.
Old 02-07-2011, 10:10 AM   #5 (permalink)
nvr8nf's Avatar
Current Sled(s): 2010 Rush
Favorite Riding Area: Michigan
Riding Since: 1988
A good trick is too "blip" the choke quickly then give it gas and see if the bog gets worse or better. If it gets better then you are lean and have to richen up the carbs. If it gets worse you are rich and have to lean them out. USUALLY when you have to "feather" the throttle it's a lean condition.
When you cleaned the carbs did you make sure all the openings/passages in the carbs were clear?
Snowmobiling - One broken heim joint away from death.
nvr8nf is online now   Reply With Quote
Old 02-07-2011, 10:28 AM   #6 (permalink)
Member
awames76's Avatar
id say its rich, ive cleaned alot of carbs its clean, my old cat had mice nest in the intake and filled the carb bowl with pee and i got them running like new. im going by what was in there when i got the sled. the owner said it ran good so im going to try to check the timming first
Old 02-07-2011, 10:28 AM   #7 (permalink)
Member
awames76's Avatar
what marks do u use
thankyou
Old 02-07-2011, 10:45 AM   #8 (permalink)
Riding Since: 1977
.173" BTDC measured on the Mag side piston with a dial indicator will be 28 degrees. Turn the flywheel in the opposite direction of rotation about .100" and then bring back to the correct reading. Mark the flywheel and housing with some chalk or a marker. Acceptable variance is one mark in either direction (.156-.191). An extra set of hands can be very handy if you have one around to help hold things in place while you make your marks.
Old 02-07-2011, 12:20 PM   #9 (permalink)
Current Sled(s): 09 Apex LTX 10 Vector LTX 96 500SKS
Previous Sled(s): 96Ultra 95XLTSP 72 440TNT 73 SW433 69 Panther 399
Favorite Riding Area: Central/North MN
16-17 Mileage: 360
15-16 Mileage: 468
14-15 Mileage: 784
13-14 Mileage: 2500
Riding Since: 1976
My 96 500 SKS Carb had a bog right at engagement (~3500rpm) that would really be bad at warmer temps. Put a Polaris Blue spring in it with stock weights and problem gone.
Not sure if this will help you but thought I'd offer it.
Good Luck!
Steve
engineman is online now   Reply With Quote
Old 02-07-2011, 10:47 PM   #10 (permalink)
Member
awames76's Avatar
thankyou for your help ill work on it this week and see if the timming if off, im sure it is because i had the coil out.
