EFI TO CARB CONVERSION 95 INDY 500 MOTOR - HCS Snowmobile Forums
Old 02-18-2010, 12:52 AM   #1 (permalink)
Member
CHAINSMOKER's Avatar
Current Sled(s): 1998 XC 700
Previous Sled(s): 1989 INDY 500
Favorite Riding Area: CHAIN O LAKES
Riding Since: 1995
Smile
i,m trying to convert a 95 efi motor in to carb. it runs but the carbs are flooding (excessive fuel pump pressure) the lower end is the same as a carburated engine accept the spot where you hook up the hose for the pump is not drilled out. so i tryed to drill it in the sled but i think the whole is to small. which means i have to pull the motor again and hope the shavings don't go down in to the crank. now i'm thinking i should just get a gasket set and use the other parts i have. long story short. i'm probably FU*KED until next season.
CHAINSMOKER is offline   Reply With Quote
Old 02-18-2010, 10:31 AM   #2 (permalink)
D-rail's Avatar
Current Sled(s): 2016 AXYS 800 Rush Pro S
Previous Sled(s): Polaris, Ski-Doo, Yamadog, Rupp, G-Whiz, Scrap Iron, etc.
Favorite Riding Area: roller coaster stuff
16-17 Mileage: 3605
15-16 Mileage: 3339
14-15 Mileage: 2385
13-14 Mileage: 3900
Riding Since: 1973
Welcome to HCS! If you drill out that hole, put a dab of grease on the flutes to grab any aluminum shavings that come out, drill a few seconds and then pull it out, clean and repeat. You running a regular (impulse style) pump then? I did this conversion to my '93 500, EFI sucked, put a set of 38's on and still got over 15 mpg, ran great. I did have to modify the boots to match the airbox and cylinder fit-up.
A few years ago, Minnesota banned the sale of youth atv's and minibikes/small motorcycles due to lead. Yep, there's lead in the batteries.
D-rail is offline   Reply With Quote
Old 02-18-2010, 12:55 PM   #3 (permalink)
Member
Riding Since: 1995
QUOTE (D-rail @ Feb 18 2010, 10:31 AM)
Welcome to HCS! If you drill out that hole, put a dab of grease on the flutes to grab any aluminum shavings that come out, drill a few seconds and then pull it out, clean and repeat. You running a regular (impulse style) pump then? I did this conversion to my '93 500, EFI sucked, put a set of 38's on and still got over 15 mpg, ran great. I did have to modify the boots to match the airbox and cylinder fit-up.[/b]
thanks for the advice. is the regular (impulse style) pump ok to run with this conversion? do you suppose the hole is to small and that is why i'm getting excessive gas to the carbs? no gas is coming out the over flow, the fuel air screw is adjusted 1/2 turn out, my choke is in as far as it will go w/out not being able to use it. that is the only thing i can think is causing it to flood.
thanks again D.
P.O.S. SNOWMOBILE!
Old 02-18-2010, 01:09 PM   #4 (permalink)
Super Moderator
XCR1250's Avatar
Current Sled(s): XCR 800
13-14 Mileage: 1,864
Riding Since: 1959
No fuel screw on round slide carbs.
Why would you believe the fuel pump pressure is excessive? Did you measure it?
Pressure test the carbs, dry and wet.
Old 02-18-2010, 05:47 PM   #5 (permalink)
D-rail's Avatar
16-17 Mileage: 3605
15-16 Mileage: 3339
14-15 Mileage: 2385
13-14 Mileage: 3900
Riding Since: 1973
The pump used on the EFI is an electric one, it puts out more pressure than you need. Use the standard impulse style pump. What are the carbs off of? Check your jetting to match what the stock carbs had, both mains and pilots (The 1995 parts list calls for 300 sized mains, and #40 for pilots- my '93 used 280 mains). Most Mikunis are set between one and three turns out on the fuel/air screw, anything out of that range means using bigger or smaller pilots. Turn in (clockwise) to block air passage into the idle circuits, makes it run richer. Check the inlet valves, make sure they don't leak, like XCR1250 says, pressure test them.
Old 02-19-2010, 01:41 AM   #6 (permalink)
Member
Riding Since: 1995
QUOTE (XCR1250 @ Feb 18 2010, 01:09 PM)
Pressure test the carbs, dry and wet.[/b]
P.O.S. SNOWMOBILE!
Old 02-19-2010, 01:50 AM   #7 (permalink)
Member
Riding Since: 1995
carbs are flooding the motor. it wants to run but floods out. using 38 carbs. how do i ( Pressure test the carbs, dry and wet?)?.
P.O.S. SNOWMOBILE!
Old 02-19-2010, 02:05 AM   #8 (permalink)
Member
Riding Since: 1995
QUOTE (D-rail @ Feb 18 2010, 05:47 PM)
The pump used on the EFI is an electric one, it puts out more pressure than you need. Use the standard impulse style pump. What are the carbs off of? Check your jetting to match what the stock carbs had, both mains and pilots (The 1995 parts list calls for 300 sized mains, and #40 for pilots- my '93 used 280 mains). Most Mikunis are set between one and three turns out on the fuel/air screw, anything out of that range means using bigger or smaller pilots. Turn in (clockwise) to block air passage into the idle circuits, makes it run richer. Check the inlet valves, make sure they don't leak, like XCR1250 says, pressure test them.[/b]
no carbs. was efi. trying to convert to carb. no pulsater hook up had to drill out & add hook up. went from no gas to too much gas.270 jets or is it 240? getting ready to get a full gasket kit,use extra parts & ride next year. unless another snowstorm comes this way.
P.O.S. SNOWMOBILE!
Old 02-19-2010, 10:00 AM   #9 (permalink)
Member
Riding Since: 1995
QUOTE (CHAINSMOKER @ Feb 19 2010, 02:05 AM)
no carbs. was efi. trying to convert to carb. no pulsater hook up had to drill out & add hook up. went from no gas to too much gas.270 jets or is it 240? getting ready to get a full gasket kit,use extra parts & ride next year. unless another snowstorm comes this way.[/b]
P.O.S. SNOWMOBILE!
Old 02-19-2010, 10:08 AM   #10 (permalink)
Member
Riding Since: 1995
i turned the f/a screws out 3 turns got it to run. speedo doesn't work but it seems like i can only get her up to 30-35 mph. w/idle screws all in it's idling at about 1k rpm barley running. smoking a lot i'm thinking too much oil? don't want to lean her out too much & blow it.
P.O.S. SNOWMOBILE!
