Track adjusting bolts - HCS Snowmobile Forums
Old 02-02-2007, 10:01 PM   #1 (permalink)
sledshed's Avatar
Riding Since: 1983
I finally am replacing the track in my wife's sled (94 Indy 500 EFI). I was pulling the rear skid when one of the track bolts snapped of and was stuck in the aluminum housing that they theard through. Forunately I was able to get it out with a lot of hassle. I stopped by the dealer and picked up a couple of new ones and figured I would replace them both. Iwas thinking of coating them with sythetic grease or using 242 threadlocker to keep them from corroding in the aluminun housing. Anybody have any other ideas?? Trying to avoid having thge same problem again. Thanks.
Previous Sleds: 1971 OLYMPIQUE 399 ,1972 TNT 640 ,1976 SKIROULE LASER 440 ,1976 MOTO SKI NUVIK 340 ,1977 MOTO SKI NUVIK 340 ,1980 MOTO SKI MIRAGE SPECIAL 377 (HAD 2 OF THOSE) ,1986 POLARIS INDY 400 , 1994 POLARIS INDY 500 EFI
sledshed is offline   Reply With Quote
Old 02-02-2007, 11:19 PM   #2 (permalink)
AKRAY4PLAY's Avatar
http://www.amazon.com/exec/obidos/ASIN/B00...om-20/ref=nosim
use this.
AKRAY4PLAY is offline   Reply With Quote
Old 02-04-2007, 11:46 AM   #3 (permalink)
Grease,never sieze both work fine,just loosen them up at least once a year and run them back and forth to keep them from siezing.
Ain't no fun waiting 'round to be a millionaire
nhgator is offline   Reply With Quote
Old 02-04-2007, 10:55 PM   #4 (permalink)
ttyR2's Avatar
Anti-sieze is where it's at.
ttyR2 is offline   Reply With Quote
Old 02-06-2007, 06:38 PM   #5 (permalink)
bleedinJDgreen's Avatar
I would stray away from using grease or anit-sieze on the mounting bolts...have always been told to use red locktite (atleast blue). Reason for this is because those bolts have a tendancy to loosen up over time while riding, and will wear out the tunnel around the suspension mounting holes. Do what you want, but I have seen this happen more than once, then it's a pain in the ass to fix. Way more work than having to fight the locktite or a broken bolt.
bleedinJDgreen is offline   Reply With Quote
Old 02-06-2007, 10:35 PM   #6 (permalink)
Go2sno's Avatar
Favorite Riding Area: 906 north of 28
16-17 Mileage: 8
15-16 Mileage: 800
14-15 Mileage: 1200
Riding Since: 1977
Use anti-seize on the track adjuster bolts. Jam nut will prevent from loosening and you'll never have a problem again. Do not use anti-seize on the bolts that mount the suspension to the tunnel. Polaris had big problems with bolts loosening, especially on the old xtra-12. Used to hit them with carb clean, blow out with air, add red loctite on a heated bolt, tighten up and go.
Go2sno is offline   Reply With Quote
Old 02-09-2007, 09:47 AM   #7 (permalink)
dodger's Avatar
Current Sled(s): 2008 IQr, 2008 IQrr, 03 pro-x600
Previous Sled(s): still have 98xc7 220 motor
Favorite Riding Area: Mancelona cabin "Oleo Acres"
I would stray away from using grease or anit-sieze on the mounting bolts...have always been told to use red locktite (atleast blue). Reason for this is because those bolts have a tendancy to loosen up over time while riding, and will wear out the tunnel around the suspension mounting holes. Do what you want, but I have seen this happen more than once, then it's a pain in the ass to fix. Way more work than having to fight the locktite or a broken bolt.[/b]
They are talking about the ADJUSTING bolts...
I've never had a 10,,,,But I've had 5 twos
dodger is offline   Reply With Quote
Old 02-09-2007, 01:33 PM   #8 (permalink)
500sks's Avatar
Current Sled(s): 2016 Switchback 600 Pro-S Red
Previous Sled(s): 2012 Switchback 600 Pro-R 2002 XCSP 600 136" 2000 XCSP 600
Favorite Riding Area: Northwoods Passage
16-17 Mileage: 537
15-16 Mileage: 985
14-15 Mileage: 971
13-14 Mileage: 1355
Riding Since: 1970
Every bolt on a snowmobile should have either antisieze or loctite. In this case I always lube the track tension adjusting bolts with anitsieze and loctite the bolt on the bolt for the rear axle bolt.
500sks is offline   Reply With Quote
