EZ-throttle - HCS Snowmobile Forums
Old 03-08-2006, 07:56 PM   #1 (permalink)
Current Sled(s): Indy 500 modified
Favorite Riding Area: Muskokas
So what exactly is EZ throttle and how does it make it easier on the hand??
-is it better for small hands (less angle to the lever)?
-does it make a big difference?
-how does it work?
thanks.
eddie jr is offline   Reply With Quote
Old 03-08-2006, 08:07 PM   #2 (permalink)
500sks's Avatar
Current Sled(s): 2016 Switchback 600 Pro-S Red
Previous Sled(s): 2012 Switchback 600 Pro-R 2002 XCSP 600 136" 2000 XCSP 600
Favorite Riding Area: Northwoods Passage
16-17 Mileage: 537
15-16 Mileage: 985
14-15 Mileage: 971
13-14 Mileage: 1355
Riding Since: 1970
-how does it work?
thanks.
<div align="right">
The angle of the flipper is about the same but the flipper has a dual pivot point so it is much easier to pull for about the first half of the travel. Yes it makes a big difference, I put one on my old 500 for my wife and she really like it. For small hands it is easier to pull but if you are trying to pull 38mm carbs you still need a flipper with a big angle to get a full pull. My wife prefers the easy throttle to the throttle on my edge. Hope this helps.
500sks is offline   Reply With Quote
Old 03-08-2006, 10:19 PM   #3 (permalink)
michahicks's Avatar
Favorite Riding Area: Northern Lower and UP
Riding Since: 1969
I would highly recommend it for small hands. I've heard it described as dual rate. It starts out very easy, using about half of the levers travel for about 1/4 of the total slide movement (more than enough for most trail). Then it crosses over to the higher rate, gets much stiffer, and the last half of the levers travel opens the slides the top 3/4 travel. If you are going to get one, make sure it's the right one for your carbs. One for 34's is not going to open a set of 38's all the way.....
michahicks is offline   Reply With Quote
Old 03-08-2006, 10:44 PM   #4 (permalink)
ok, thanks for the tips guys. My fiancee definitely had troubles with mine. I don't because of my bigger hands I guess. Although I think someone swapped it out originally because it was supposedly standard on my sled...weird?
So it doesn't affect performance in any way does it? You still get all the pick-up and top end you would otherwise have, correct?
Old 03-09-2006, 06:08 AM   #5 (permalink)
thinksno's Avatar
Brochure mistake, only came standard on the 03. Good for small hands, gives a false feel the sled has less power due to longer squeeze.
thinksno is offline   Reply With Quote
Old 03-09-2006, 07:22 AM   #6 (permalink)
michahicks's Avatar
Riding Since: 1969
<<<So it doesn't affect performance in any way does it? You still get all the pick-up and top end you would otherwise have, correct? >>>
Correct, you maintain 100% of the throttle range. No losses of any kind.
Old 03-09-2006, 07:26 AM   #7 (permalink)
bobg57's Avatar
i installed one, tried it a few times,didn't like the awkwardness of it, took it off and put it in the rest of the junk pile (thats the stuff that i wasted money on and will probably never use again)
Current/Past Sleds
Ski Doo 06 GSX 800
Polaris 03 Classic 600, M-10 susp
Polaris 96 Indy Trail
Polaris 01 XCSP
bobg57 is offline   Reply With Quote
Old 01-15-2017, 09:46 AM   #8 (permalink)
trdehmer's Avatar
Current Sled(s): 2016 Axys SB 800 ProS & 2015 Axys SB 800 60th
Riding Since: 1984
Anyone know where to find one of these? Need one for a 2000 XC700...
Previous Sleds:
2012 F1100 Turbo 50th
2010 Z1 Turbo LXR
2003 F7 SP
2002.5 ZR900
1999 XC 700 SP
1994 XLT SP
1990 Polaris 500
1990 Polaris 340 Sport
1984 Polaris 480 Trail
A Phazer
1969 Massey Ferg Ski Whiz
trdehmer is offline   Reply With Quote
Old 01-15-2017, 05:20 PM   #9 (permalink)
Favorite Riding Area: Ma.
15-16 Mileage: Zero
14-15 Mileage: not much
Riding Since: 70 s
Originally Posted by 500sks View Post
[/b]
The angle of the flipper is about the same but the flipper has a dual pivot point so it is much easier to pull for about the first half of the travel. Yes it makes a big difference, I put one on my old 500 for my wife and she really like it. For small hands it is easier to pull but if you are trying to pull 38mm carbs you still need a flipper with a big angle to get a full pull. My wife prefers the easy throttle to the throttle on my edge. Hope this helps.[/QUOTE] The EZ throttle works great, but you will notice a bigger gap between the end of the flipper and the bar. Helps to have a bigger hand...especially with 38mm carbs.
Old 01-16-2017, 07:15 AM   #10 (permalink)
trdehmer's Avatar
Riding Since: 1984
Where can a person purchase an EZ Throttle these days?
Previous Sleds:
2010 Z1 Turbo LXR
2003 F7 SP
2002.5 ZR900
1999 XC 700 SP
1994 XLT SP
1990 Polaris 500
A Phazer
