05 MXZX Gauges Don't Work - HCS Snowmobile Forums
REV Chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 09-04-2011, 02:44 PM   #1 (permalink)
Current Sled(s): 05 MXZX 800, 03 MXZ600 H.O
Previous Sled(s): 98 MXZ 670
Favorite Riding Area: Mactaquac, NB
13-14 Mileage: 600
Riding Since: 5
Default 05 MXZX Gauges Don't Work
I just bought a 05 mxz and found that the gauges wont work. Headlights work fine and odometer work fine just no tach and speedo. Got another relay and more fuses and switched them all and still nothing. anyone have any ideas??
NBDooRider is offline   Reply With Quote
Old 09-05-2011, 01:49 AM   #2 (permalink)
Current Sled(s): 07 Gade 800HO
Previous Sled(s): 99 MXZ 600
Favorite Riding Area: Bottineau, N.D. Bemidji, Mn.
Riding Since: 1999
Disconnect the connectors and check them for corrosion. Not likely since they are pretty much protected by the sled body. Securely fasten them and start it up. If this doesn't work disconnect the ECM and check it and the connector contacts for corrosion. Clean if necessary/reconnect and start her up.
Fixed?
bELOWzERO is offline   Reply With Quote
Old 09-05-2011, 12:18 PM   #3 (permalink)
13-14 Mileage: 600
Riding Since: 5
So i disconnected everything and checked for corrosion and there was none. they had dielectric grease on all the contacts. what should i do now?
Old 09-05-2011, 04:44 PM   #4 (permalink)
Member
Replace the relay under the console, don't buy the Doo one they want $35 for it. Just go to napa and get it for $5.
TwoSmoke is offline   Reply With Quote
Old 09-05-2011, 04:56 PM   #5 (permalink)
Riding Since: 1999
I believe he did that already. I get off work in about an hour. When I get home I'll look at the wiring diagram and see if I can help some more.
Old 09-06-2011, 09:58 AM   #6 (permalink)
Riding Since: 1999
Default gauges
Read the voltage off the battery, what is it? Do both gauges fail to light up? Does on light and not the other? Let us know and we can go to the next step.
Old 09-06-2011, 08:39 PM   #7 (permalink)
13-14 Mileage: 600
Riding Since: 5
I went to a friends place and grabbed his tach, speedo and relay off of his 07 800 and come to find out my speedo is toast. i plug my tach in with his speedo and everything works. Weird but that is what my conclusion is. Does it sound right, the tach has to run through the speedometer??
Old 09-14-2011, 04:30 PM   #8 (permalink)
Riding Since: 1999
That's exactly how it's wired. I was hoping your battery was low and needed charging. If you haven't bought one yet check these guys out. OEM equipment and the cheapest I have found.
www.partspitstop.com
There is also a salvage yard not far from me I deal with frequently, I give him a call if you want. Send me a PM.
Old 09-22-2011, 03:52 PM   #9 (permalink)
13-14 Mileage: 600
Riding Since: 5
Thanks belowzero
Old 09-29-2011, 09:05 PM   #10 (permalink)
chrmer3's Avatar
Current Sled(s): 13 Ren-X BC 800, 15 GSX LE, 05 Mach Z 1000
Previous Sled(s): many
Favorite Riding Area: Pittsburg, NH
15-16 Mileage: 750
14-15 Mileage: 4000
13-14 Mileage: 2000
Riding Since: 1982
Any chance I can buy the old broken speedo? I need the rubber grommet for the reset button badly! If you need another speedo I have one you can have if I can have the old one- lol... I need that grommet!!
chrmer3 is offline   Reply With Quote
