2005 500ss guage problems - HCS Snowmobile Forums
REV Chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 08-15-2010, 08:54 PM   #1 (permalink)
Newbie
I just bought 2005 500ss and the guages worked fine and now dont work at all. All wires are connected and fuses are fine. What is my problem??
heafie13 is offline   Reply With Quote
Old 08-17-2010, 10:42 AM   #2 (permalink)
snowmutt's Avatar
Previous Sled(s): 00 mxz 500...gade,now..05 ss custom gade
QUOTE (heafie13 @ Aug 15 2010, 07:54 PM)
I just bought 2005 500ss and the guages worked fine and now dont work at all. All wires are connected and fuses are fine. What is my problem??[/b]
Sounds like the relay..known to blow and guages go dead.
Try re placing it , you can get them at Napa for like 6 bucks vs's the 30 at the dealer.
The relay is located above the secondary on the frame..little blk thing that plugs into harness.
Think it's AR 21 by napa's #'s, take your old one with you
mutt
snowmutt is offline   Reply With Quote
Old 08-17-2010, 11:36 PM   #3 (permalink)
rocksnap's Avatar
Current Sled(s): 09' 1200 TNT
Previous Sled(s): 05' 500ss RevGade
Favorite Riding Area: Da Burg
13-14 Mileage: 271
Riding Since: 2006
there is a relay under the left side of the cluster, it is a common failure. you can pay upwards of $35 for the relay at the dealer. or you can pay less than $10 at your local automotive store. do a search here or over at dootalk and you will find the part number, location of exact fuse etc...
rocksnap is offline   Reply With Quote
Old 10-17-2010, 09:49 AM   #4 (permalink)
Member
chek your ground plug, I had the same problem when i rebuilt my motor. Its down behind the exhaust can
mach boy is offline   Reply With Quote
Old 12-20-2010, 10:05 PM   #5 (permalink)
Current Sled(s): 2005 Skidoo GTX 500SS
Favorite Riding Area: Right out the Garage
mutt
http://www.mainesledder.com/showthread.php?t=1473
Standard Motor Products (STD): RY115 - w/ mount tab
RY116 - no mount tab
PANASONIC: CB1-12V - 40A - 5 terminal - no bracket
CB1a-12V - 40A - 4 terminal - no bracket
CB1-M-12V - 40A - 5 terminal - bracket mount
CB1a-M-12V - 40A - 4 terminal - bracket mount
BOSCH:
0 332 019 103 - 50 amp - 4 terminal - no bracket - Suppression: R
0 332 019 110 - 50 amp - 4 terminal - bracket mount - Suppression: R
0 332 209 137 - 50 amp - 5 terminal - no bracket - Suppression: R
0 332 209 138 - 50 amp - 5 terminal - bracket mount - Suppression: R
0 332 019 150 - 40 amp - 5 terminal - bracket mount
0 332 019 151 - 40 amp - 5 terminal - no bracket
0 332 019 155 - 40 amp - 5 terminal - bracket mount - Suppression: D
0 332 209 150 - 40 amp - 5 terminal - bracket mount
0 332 209 151 - 40 amp - 5 terminal - no bracket
0 332 209 159 - 40 amp - 5 terminal - no bracket - Suppression: R
0 332 209 161 - 40 amp - 5 terminal - bracket mount - Suppression: R
0 332 209 168 - 30 amp - 5 terminal - no bracket
FORD PART#: FOAZ-14N089-A (F0AB-14B192-AA printed on it)
NAPA Echlin: AR143 has the mount tab
AR204 has the mount tab & Suppression Resistor
AR201 has no mount tab
RADIO SHACK: 40 Amp - 275-001
30 Amp - 275-226
Installed
bhshaman is offline   Reply With Quote
Old 12-22-2010, 08:04 PM   #6 (permalink)
Member
Default Gauges
My son washed the sled after months of storage(09 MXZ 550X) the other day and since then there is a gauge and Tach problem as well. It worked fine before and now when I start the sled both gauges seemed to be miscalibrated. The Tach reads 3500rpm and the speedometer is 25 mph while idling. No doubt he probably sprayed the crapped out of it, any reccommendations.
schooner is offline   Reply With Quote
