| REV Chassis This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#1 (permalink) |
Newbie
Hello, I am new at posting to this thread but read it all the time, good site and good people on here. To the problem, I bought a 2003 Ski Doo MXZ Rev 800 sport a couple months ago, was having idling issues and took the carbs off and cleaned them, I found at that time the carb boots had rips or holes in them, I guess the delaminating issue. So I ordered v-force 3 reeds, and at the same time I got a sno stuff can for it. I know have all of them on and I am having a hanging idle issue still, I have tried adjusting the idle screw and fuel screw. I also had a loaping issue at low rpm or speed, oh yeah the sled is clutched also, by adjusting the fuel screw it helped that, not gone completely but helped alot! It will hang around 2500 to 3000 rpm and then drop down, if I adjust the idle screw up it stays up, then If i adjust it down then when it comes down it dies after a few seconds. I did not rejet, do I need to do this now that I have added a can and v-force reeds? Or do I have another issue? Any help would be greatly appreciated. Thanks Tom
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Current Sled(s): 02 mxz 700, 05 mxz 550f
Previous Sled(s): Polaris,Skiroule
Favorite Riding Area: Bayfield,Wisc.
10-11 Mileage: 200 mi
Riding Since: 60's
Are you sure you don't have any air leaks around the cases or carbs? Other wise how far are your fuel screws turned out? if they are at about 2 turns out then I would put bigger pilots in it. thats the rule of thumb if you can go out 2 turns and still have that hanging idle jet up the pilots then turn your fuel screws back in to about 1 turn out and check it. if it runs rich turn it a 1/4 turn in if it still hangs turn out a 1/4.........good luck as far as jetting for your v-force call them and ask them what you should do. earlier 800's ran #20 pilots then they went to 17.5's and started having the hanging problem
#3 (permalink) | |
Current Sled(s): Gade800/ ZRT800
Previous Sled(s): Too many to list
Riding Since: 1973
X's 2 on the above, its great sound mechanical advice. Good call rblscoot, to the point and simple to follow directions.
-This Years Toy- 05 Renegade 800HO P-Tek 07 Needles & #20 Pilots Gold Finger Lefty Throttle 22/43 Gearing Floated Team Secondary Summit Highmark X Pkg Rear Springs 136"X16"X1.250" Powder Max 108 Woody-1.325's In Double Backers Graphite Slides Extra Wheel Kit w/Billet Wheels Spare Gas Caddy C&T Alum. A-Arm Protectors RevKneez Pads SlyDog 7" PowderHounds Holeshot Skid plate Ram Mounted Garmin 60CSx
#4 (permalink) |
Newbie
Hey thanks guys, I will call them this week and find out what they say at v-force, I am sure it has the stock jets, I believe I am currently at 1 1/2 turns out, I will try the two turn rule of thumb and see what happens, any body know were you can buy the jets at? Thanks Again
#5 (permalink) | |
Newbie
#6 (permalink) |
Newbie
rblscoot, thanks so much, I called vforce and they told me about the upping the pilot jet also. I ordered two of them got them put in tonight, and walla, took care of all the problems, I went from 17.5 to 20's. Also set the fuel screw to 1 1/2 turns out. No more surging when taking off and at slow speed, and this took care of the hanging idle issue. It comes right down know and idles smooth, I have it set to about 1600 rpm, is that to low or does it need to be higher? Thanks so much you guys this is a great web site with some knowledgable people!
#7 (permalink) |
Current Sled(s): ski doos mostly
Previous Sled(s): lots of em
Favorite Riding Area: mountains or rivers or woods
Riding Since: 1980
did you try toput a little slack in your throttle cable?sometimes when its tight the idle will hang
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
