How to diagnose no Spark Arctic Cat - HCS Snowmobile Forums
Arctic Cat General Discussion This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. This is a 100% NO BASH ZONE. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. Posting private messages from Members or Site Staff is against site rules and will be subject to banning from site temporarily or permanently. Full Throttle Speed
Old 02-21-2011, 03:13 PM   #1 (permalink)
rascal810's Avatar
Current Sled(s): 2006 FST
Previous Sled(s): Too Many to list
Favorite Riding Area: Local
Arrow How to diagnose no Spark Arctic Cat
If this is already on here let me know but I didnt see it.
I get asked this question at least twice a week at the shop so here a write up goes...
This is for most arctic cat sleds. This will not work for you if you have points and condensers and on some newer sleds. To see if this will work for you pop you hood and look at the wires coming out of the stator. There will be two yellows, a black and a brown wire but sometimes the black wire will be subbed out for a different color like purple or purple with black or another color.
NOTE: Some sleds loop a brown wire coming from the stator back to the engine for a ground, make sure this is not broken. Also some sleds have a brown wire coming from the CDI box that grounds on the engine. Make sure it is not broken.
There are two types of cat ignitions. Normally open and normally closed so you will have to do two test.
Unplug the four prong connector that I talked of and check for spark. Do not have caps on plugs in engine because if it starts it will be complicated to shut off. If no spark put a jumper between the two non yellow wires on the engine side of the connector. Now check for spark again. If still no spark the problem is not with any of the switches or the wiring harness. If you got spark one of these ways you have a problem with one of your switches or wiring connectors.
Now check the stator to get a spec for your stator go to https://www.rmstator.com/en/index.htm and they have the specs listed for most cat stators. If you stator checks out good check you trigger coil if your sled is equipped. Ohm between the two wires, you can probably find the spec for yours online somewhere. If its ok go to your coil. You should be able to find a spec for it online also. If everything checks out then chances are you need a CDI box.
ID:	481154   Click image for larger version
ID:	481155   Click image for larger version
rascal810 is offline   Reply With Quote
Old 02-22-2011, 07:55 AM   #2 (permalink)
blaine's Avatar
Current Sled(s): 1107 tigershark & Stock 1000
Riding Since: 1986
Open Ignition: 1998 and newer ZR’s and ZL’s 1998-2002 ZRT 600,800 and 1000 with the exception of the 1997 ZR 580 that is an open ignition. With open ignitions a live wire goes from the ignition system to all of the switches. The switches are normally open, or not making connection, until in the "OFF" position. When in the "OFF" position the switch will ground the ignition wire to the chassis effectively killing the spark. If a connecter becomes 100% disconnected or if a wire gets cut then the switch will no longer turn off the engine but the engine will still start and run.
Diagnosing no spark, weak spark or intermittent spark issues
First is separating the issue between switches or the primary ignition components like the stator, cdi, coils, trigger coil or possibly plugs or plug wires or plug caps.
  • First put the spark plugs in the spark plug boots and lay them on the cylinder head bolt away from the cylinder plug hole so they are grounded. If you pull the sled over and the spark plug is over the spark plug hole and it sparks it will ignite.
  • Pull the recoil rope and check the spark at the plug. Is there spark? Is there spark at each spark plug? Is the spark blue indicating a strong spark or is it orange/yellow indicating a “weak” spark. If you have nice blue spark on one plug (if it is a twin) or two plugs (if it is a triple) and not the others, it may be as simple as having a bad/fouled out plug. Try replacing the non-sparking spark plug with a new spark plug.
  • The next step is pretty much the same whether you saw no spark or a weak spark. You unplug the 4-prong connector coming from the stator containing the 2 yellow wires. On some EFI sleds you have 3 yellow wires and one non yellow (ground) wire. The extra yellow wire is used for powering your fuel pump. The other 2 yellow wires in the 4-prong connector sends the power to the lights/hand warmers/tachometer. When you unplug this 4-prong connector (3 prong on the 1998-1999 500/600 EFi sleds) you are bypassing all of your switches (Throttle Safety Switch, Kill, Tether ect..) and all of your lights, hand warmers ect..in your handlebars. Pull the recoil over and see if you have spark or if the spark is now blue. Carbureted models can be started and run with this 4-prong connector unplugged but you won’t have lights ect..as mentioned above. If you have an EFI, you can only check for spark and it will not start or run with it unplugged. You can run a battery to the fuel pump with it unplugged and it can/will start and run.
  • If you had no spark and by unplugging the 4-prong connector you now have spark, that tells you that you have something shorted out in your hand controls, switches like the tether, throttle safety switch or kill switch. If you had weak spark and now have blue spark it also tells you that you have a short or a problem with one of your switches. The most likely culprit is the TSS or kill switch, There is a 3 prong connector in your handlebars that if you unplug it will bypass your kill and TSS switch and you will only be able to start and turn off your sled using the key. The 3 prong connector is not by your throttle but rather just a little bit down the steering shaft about at the point where the console containing the key switch is located. If you’re not sure which connector it is, just follow the wires out of the right handlebar area where the TSS and Kill switch are located down to where the plug is located. There are other plugs in the handlebar area by the right side by the thumb throttle containing yellow wires for your hand warmers.
  • If after unplugging the 4-plug connector there is no spark or the spark still looks weak, this tells you that the problem is in the major ignition components like the stator, coils, cdi, spark plugs, spark plug wires, possibly a short in the wiring harness or a bad trigger coil.
  • First check the connections from the stator to the cdi. Make sure all connections are free of moisture, tight and use a small amount of dielectric grease. Check the ground. You have a ground wire coming from your stator and your CDI/ECU box. Make sure the ground is clean, tight and that the ground wires are not broken/loose. Sometimes the ground wire is pinched and broken inside the eyelet connection and is making only intermittent if any connection. Some older model Arctic Cats have the ground up closer to the handle bars on what is considered the “firewall” of the sled and they rust/corrode badly.
  • If all connections are solid and the ground looks good then you start electrically checking components. Most twin trigger coils ohm specs are 90-100 or so ohms with new ones up to 115. Triples are usually 175 ohms. The frustrating part about the trigger coil is that it can test good, but still be bad. I have a video on youtube showing how to do this.
  • Next test the stator itself. I have several videos on youtube showing how to test several models. Triple cats and ZR/ZL 500/600 carb sleds have the 4 prong connector. The ZR/ZL 500/600/580 EFI’s have the clear 3 prong rectangular plug and many of the 580/700 carbs have a triangular plug.
  • If you have no spark and your trigger tests ok and your stator tests ok then we may be looking at a secondary coil issue. The coils can have a couple of issues with them. The first thing you want to do is make sure the spark plug caps are on tight and are clean. They just screw on and off the spark plug wire. If your wires are long enough unscrew the spark plug caps, trim ¼ to a ½ inch off the end of the wire and then screw the spark plug cap back on. Also, on some coils you can unscrew the wire from the coil itself and trim that end too. Be warned though that I did have one wire that would not unscrew from a coil and I ended up tearing the spark plug wire. Also, always check the spark plug gap and set it to the correct specs. Spark plugs with the gap set too small on them can make the motor run poorly.
  • If you have no spark and your trigger tests ok, your stator tests ok and you have tried a new set of coils then we’re possibly looking at a bad CDI box. There is no real good way to test the CDI other than swapping the box out with a known good CDI box.
11. Specificly on Battery EFI sleds check the 2 realys on the back of the ECU. A 1996 EXT EFI has 1 relay for the spark and 1 for the fuel pump.
12. Bad reeds on a sled will cause it to back fire and run poorly making it act like it is an electrical issue.
  • Other issues related to a no spark/Weak Spark/Wet Plugs issue:
  • Wrong flywheel on it.
  • Frayed wires in the wiring harness or under the seat caused a short
  • Sled was only running on one cylinder. Low side coil on his stator read 360 ohms and it should have measured 450 ohms. The low side coil was bad.
  • It kept fouling plugs left and right. The guy before me ran ethanol, and never told me. This was on an EFI sled.
  • Hood harness was routed between rewind/stator housing and frame and had 4 wires smashed. Repaired wires and ran good.
  • Got it running again tapped the ECU and died. Pulled the ECU cover off and found some corrosion
  • Wires running to the carbs were rubbing against the jack shaft (Shaft going from secondary clutch to the top sprocket in the chain case). After rewrapping/rerouting the wires it ran great
  • Bolt for the recoil cup broke off and hit the trigger coil, bent the bracket slightly and gave it too much air gap. Air gap between the trigger coil and flywheel should be around .010-.020. I know it will not fire if the gap is .040.
  • Oil Injection turned up too high
  • Fuel Lines hooked up backwards
  • Lean jetting will cause a bog. The sled would start and idle but if you pinned the throttle the sled would bog and quit running. We were able to determine that it ran better when you choked it a little. We jetted up and it ran good.
  • Sheared Timing key
  • Crank out of Phase will cause it to run very poorly.
  • Too much dielectric grease in the trigger connector caused sled to bog.
  • Bad TPS Switch/TPS wires shorting/grounded
  • The wire on the carburetor was put on backwards
  • Loose Key switch wire
  • a loose terminal on the key switch
Harness got to close to the pipe and fused wires together causing no spark issue
Wanted: Dead 1990's era Stators and CDI boxes
The link below leads you to my Cat electrical diagnosis videos.
blaine is offline   Reply With Quote
Old 02-22-2011, 07:59 AM   #3 (permalink)
blaine's Avatar
Riding Since: 1986
Closed Ignition: Primarily Pre-1998
A "Closed" ignition means the wiring needs to have a closed circuit in order to run. If the connection to any switch; key, kill, tether, throttle safetyswitch, etc.. is interrupted there will no longer be power to the ignition system and spark will cease. All Cats 1997 and earlier run a closed ignition, with the exception of the 1997 ZR 580 that is an open ignition.
First you want to see if it an issue in the switches/handlebars or if it is in the primary ignition components: stator, cdi, coils, trigger coil or possibly plugs, plug wires or plug caps.
  • First put the spark plugs in the spark plug boots and lay them on a cylinder head bolt so they are grounded. Make sure the plugs are not near the spark plug holes when you pull it over.
  • Pull the recoil rope checking the spark at the plug. Is there spark at each spark plug? Is the spark blue (indicating a strong spark) or is it yellow/orange (indicating a “weak” spark). If you have nice blue spark on one plug (if it is a twin) or two plugs (if it is a triple) and not the others, it may be as simple as having a bad/fouled out plug. Try replacing the non-sparking spark plug/plugs with new a new plug.
  • The next step is pretty much the same if you had no spark or a weak spark. On the “Closed” ignition you unplug the connector from the stator containing the yellow wires. This connector sends the power to the lights, hand warmers and tachometer. When you unplug this connector you need to put a jumper wire connecting the 2 “non yellow” wires together in the connector. This completes the electrical circuit which is needed to check for spark. I have a youtube video showing how to do this. By putting this jumper wire between the 2 non yellow wires you are bypassing all of your switches (Throttle Safety Switch, Kill, tether ect..) all of your lights and hand warmers ect..in your handlebars. Pull the recoil over and see if you have spark or if the previous yellow/orange weak spark is now blue. Carbureted models can be started and run with this 4-prong connector unplugged and the jumper wire in it but you won’t have lights ect..as mentioned before. If you have an EFI, you can only check for spark and it will not start or run with it unplugged. You need it plugged in to power your fuel pump. You can hook up a battery to the fuel pump and start it.
  • If by using the jumper wire you now have spark, there is something shorted out in your switches like the tether, throttle safety switch or kill switch. If you had weak spark and now have blue spark it also tells you that you have a short with one of your switches. Again likely culprits are the TSS, tether or kill switch. There is a 3 prong connector in your handlebars that if you unplug and jump the 2 outside prongs it will bypass your kill and TSS switch. After bypassing these switches you will only be able to start and turn off your sled with the key. I have a video on youtube showing how to do this. The 3 prong connector is usually not by the thumb throttle but rather just a little bit down the steering shaft about at the point where the console containing the key switch is located. If you’re not sure which connector it is, just follow the group of wires from right handlebar area down to where the plug is located. There are a few other plugs by the handlebar on the right side by the thumb throttle, but they contain yellow wires and are for your hand warmers and thumb warmer. You also need to bypass the tether. You can just cut the wires in the back of the tether and splice the wires together which "completes" the circuit.
  • If after unplugging the 4-plug switch and using the jumper wire you still do not have spark or the spark continues to look weak this tells you that the problem is in the major ignition components like the stator, coils, cdi, spark plugs, spark plug wires or trigger coil.
  • The first thing to check is the connection from the stator to the cdi. Make sure all connections are free of moisture, are tight and use a little bit of dielectric grease on it. Check the ground. You should have a ground wire coming from your stator and your CDI/ECU box. Make sure the grounds are clean, tight and that the ground wires are not broken. Sometimes the ground wire is pinched and broken inside the eyelet connection and is making only intermittent if any connection. Some older model Arctic Cats have the ground up closer to the handle bars on what some would consider the “firewall” of the sled and they are notorious for rusting/corroding out badly.
  • If all connections are solid and the ground checks good then you start electrically checking components. Most twin trigger coils ohm specs are 90-100 or so ohms with new ones up to 115. Most triples are 175 ohms. I have a video on youtube showing how to check it. It is very easy and quick to test. The frustrating part about the trigger coil is that it can test good, but still be bad.
  • Next you want to test the stator itself. I have several videos for different models on youtube. I have 3 separate tests using the 3 main plugs used on carb and EFI 1990’s model stators.
  • If you continue to have no spark/weak spark and your trigger tests ok then we may be looking at a secondary coil issue. First you want to make sure the spark plug caps are on tight. They just screw on and off the spark plug wire. If your wires are long enough unscrew the spark plug caps, trim a ½ inch off the end of the wire and then screw the spark plug cap back on. Also, some spark plug wires unscrew from the coil itself. I had 2 sets of coils go “bad” on my sled. My triple coils showed 1 spark plug with extraordinary blue spark and the other 2 plugs were weak/yellow-ish in color. After I trimmed them and screwed them back together they ran perfect. Warn spark plug ends usually cause a miss or acts like a rev limiter. Be warned though that I did have one wire that would not unscrew from a coil and I ended up tearing the spark plug wire. Also, always check the spark plug gap and set it to the correct specifications.
  • If you have no spark and your trigger tests ok, your stator tests ok and you have trimmed the plug wires then we’re looking at a possible bad CDI box There is no real good way to test the CDI other than swapping the box out with a known good CDI box.
11. Specificly on Battery EFI sleds here is another thing to check. There can be a bad relay on the back of the ecu. There are 2 of them back there 1 for the spark and 1 for the fuel pump.
12. Also, bad reeds on a sled will cause it to back fire and run poorly acting like it is an electrical issue.
13.Other issues that I have seen/read that have caused a no spark/bad running issue:
A. Wrong flywheel on it.
B. Frayed wires in the wiring harness or under the seat caused a short
C. Sled was only running on one cylinder. Low side coil on his stator read 360 ohms and it should have measured 450 ohms. The low side coil was bad.
D. It kept fouling plugs left and right. The guy before me ran ethanol, and never told me. This was on an EFI sled.
E. Hood harness was routed between rewind/stator housing and frame and had 4 wires smashed. Repaired wires and ran good.
F. Got it running again tapped the ECU and died. Pulled the ECU cover off and found some corrosion
G. Wires running to the carbs were rubbing against the jack shaft (Shaft going from secondary clutch to the top sprocket in the chain case). After rewrapping/rerouting the wires it ran great
H. Bolt for the recoil cup broke off and hit the trigger coil, bent the bracket slightly and gave it too much air gap. Air gap between the trigger coil and flywheel should be around .010-.020. I know it will not fire if the gap is .040.
I. Oil Injection turned up too high
J. Fuel Lines hooked up backwards
K. Lean jetting will cause a bog. The sled would start and idle but if you pinned the throttle the sled would bog and quit running. We were able to determine that it ran better when you choked it a little. We jetted up and it ran good.
L. Sheared Timing key
M. Crank out of Phase will cause it to run very poorly.
N. Too much dielectric grease in the trigger connector caused sled to bog.
O. Bad TPS Switch/TPS wires shorting/grounded
P. The wire on the carburetor was put on backwards
Q. Loose key switch wire
R. a loose terminal on the key switch
S. Harness got to close to the pipe and fused wires together causing no spark issue
Old 02-22-2011, 11:26 AM   #4 (permalink)
rascal810's Avatar
Ok you win yours should be a sticky.
Old 02-22-2011, 03:22 PM   #5 (permalink)
blaine's Avatar
Riding Since: 1986
No big deal....I continue to add to them because I learn something new all the time. As I watch my youtube videos I keep yelling at myself "Say XYZ.." ect... because there is more I have learned since I made those videos.
Old 02-22-2011, 08:53 PM   #6 (permalink)
3Cats's Avatar
Current Sled(s): z-1 ext
Previous Sled(s): 09 xfire 800 sp
Favorite Riding Area: beddington
where's the best place to get stator rewound?
3Cats is offline   Reply With Quote
Old 02-23-2011, 12:10 AM   #7 (permalink)
blaine's Avatar
Riding Since: 1986
I might know someone..
