Arctic Cat EXT 580 clutch problems...HELP!! - HCS Snowmobile Forums
Arctic Cat General Discussion This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. This is a 100% NO BASH ZONE. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. Posting private messages from Members or Site Staff is against site rules and will be subject to banning from site temporarily or permanently. Full Throttle Speed
Old 11-15-2010, 11:09 AM   #1 (permalink)
Newbie
Question Arctic Cat EXT 580 clutch problems...HELP!!
I have an AC 580 EFI MC. My drive clutch (or primary?) has new weights in it 49.5 grams and has a new red spring. I just recently replaced the roller bushings on the spider, they are brand new with brand new pins for the weights.
The problem...for some reason, I have to rev the sled up to about 4500 to 5000 rpms before the sled moves and my top speed is only about 60 MPH. I'm at 7000 rpms at 30 MPH!!!!! I did the repairs over the summer so the sled sat that whole time.
Is this a secondary clutch issue? I never touched the secondary over the summer. I have done the obviouse to fix the problem...new plugs, new belt, ect.
I need help and really appreciate any advice!!!!
bigben004 is offline   Reply With Quote
Old 11-15-2010, 02:55 PM   #2 (permalink)
ready2race's Avatar
Current Sled(s): 06" F 7- R
Previous Sled(s): 00 ' ZR 500 96" ZR 580 ,,Z440
Favorite Riding Area: 660FT
Riding Since: 1970
With that set up engagement should be around 3800,, seems like something is sticking..jack the sleds up and rev it up and watch the clutches and see how they are working,,,,R2R
WIN....LOSE..OR .....DRAW
ready2race is offline   Reply With Quote
Old 11-15-2010, 11:19 PM   #3 (permalink)
Newbie
I did jack up the sled an it seems like the clutches are working properly...one thing though, when I try to remove the belt, the secondary clutch sticks open and doesn't spring shut.
Could it be that I need to go over my secondary clutch? or could it be that my red spring is the cause? Everything worked perfectly last year till I replaced some worn parts...UGHHH.
Old 11-16-2010, 06:11 AM   #4 (permalink)
ready2race's Avatar
Riding Since: 1970
yes,you should go ever it too..you might not have enough twist on it but that won't efferect your engagement so you still have a problem there.....R2R
Old 11-16-2010, 10:03 PM   #5 (permalink)
snappydave's Avatar
Current Sled(s): '15 ZR9000LTD and '15 XF9000LTD
Previous Sled(s): '04 F5S/P,'07 F1000S/P,'07 Z1
Favorite Riding Area: HoughtonLake, Caddy, Raco
16-17 Mileage: 350
15-16 Mileage: 800
14-15 Mileage: 495
13-14 Mileage: 2100
Riding Since: 1968
EXT 580 ?? Did you put the newer 6/9 tower CAT spring in a Comet clutch? Try the old spring again, see if the prob goes away.
"He who dies with the most toys,,still dies."
snappydave is offline   Reply With Quote
Old 11-17-2010, 10:48 AM   #6 (permalink)
Newbie
Yes, EXT 580 EFI...I did use the same spring, i didn't know that mattered? Does it? It actually was just the reverse, the old comet sring in a CAT clutch...could that be my problem?
Old 11-17-2010, 12:26 PM   #7 (permalink)
ready2race's Avatar
Riding Since: 1970
Yes , it does,, the new clutches use a different diameter spring and it will bind in the older comet..Ok,,hold on, you have the new clutch on your sled? that could be part of it, you have to use the arcto springs with the new clutch,, what does you sle rev top speed now? ,, it could be cal all wrong ,, R2R
Old 11-18-2010, 02:57 AM   #8 (permalink)
90phazerII's Avatar
Current Sled(s): 2006 summit 800
Previous Sled(s): 95 cat 580, 90 phazer 480
I dont mean to thread jack......but is it bad i have never done any maintenance to my cat...except new plugs
90phazerII is offline   Reply With Quote
Old 11-18-2010, 06:53 AM   #9 (permalink)
ready2race's Avatar
Riding Since: 1970
depends how many miles you have but you should do reg maintenance, long as it's working fine your pretty ok..clutches and skid are the main thing, they are the biggest wear part....R2R
Old 03-31-2011, 07:12 PM   #10 (permalink)
90phazerII's Avatar
how would one go about doing these things? The skid is what the track rides on right? I don't ride much anymore but I would like to try an keep her in top notch shape! :P
