Cost to replace drive shaft bearings - HCS Snowmobile Forums
Arctic Cat General Discussion This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. This is a 100% NO BASH ZONE. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. Posting private messages from Members or Site Staff is against site rules and will be subject to banning from site temporarily or permanently. Full Throttle Speed
Old 01-07-2009, 09:27 PM   #1 (permalink)
Hey all. I have a '98 ZL 440 ~ 2500 miles and when riding last weekend had my speedo stop working about 30 miles from the trailer. I got back to the trailer with no problems, in fact it seemed to be running great. I investigated when I got home to find out that the PTO side bearing was shredded...seems to be a common problem. One of the steel balls was even split in half! I took it in to get fixed and they quoted me around $350 to get it fixed. Does that sound about right to get both driveline bearings replaced + labor? I just want a reality check to make sure I am not getting ripped off. It must be quite a job to replace the bearings because I know the parts are not that expensive.
birkato is offline   Reply With Quote
Old 01-07-2009, 10:10 PM   #2 (permalink)
gtfly4's Avatar
Current Sled(s): 12 M8 153
Previous Sled(s): 08 M6 152, 03 F5 SP
Favorite Riding Area: Black Hills
Riding Since: 1998
I'm waiting on two bearings for the same job on a 95 bearcat. The two bearings and new speedo adapter cost a total of around 50 dollars. I'm doing the installation myself.
gtfly4 is offline   Reply With Quote
Old 01-07-2009, 10:17 PM   #3 (permalink)
insearchofsnow's Avatar
Current Sled(s): 2015 ZR 7000 ET LTD
Previous Sled(s): 07 F6 LXR, 06 SCat 600 LXR
Favorite Riding Area: UP Michigan & Algoma
13-14 Mileage: 1500
Riding Since: 1977
Dealer quoted me 3hrs labor at $75/hr + $75 parts. I ended up doing it myself - first time doing it and it probably took me 4-5 hrs in total in my spare time.
insearchofsnow is offline   Reply With Quote
Old 01-07-2009, 11:42 PM   #4 (permalink)
Thanks for the feedback. I was going to attempt the repair myself, but feared that I may have damaged more than just the bearing and wasn't sure what else to look for. I also wasn't crazy about spending 4 hours of time on my cold garage floor doing the repair. It sounds like $350 may be a little high, but not too far out of line.
Old 01-08-2009, 12:15 AM   #5 (permalink)
gtfly4's Avatar
Riding Since: 1998
Yes, concrete floors in winter temperatures suck!
Old 02-07-2009, 01:00 PM   #6 (permalink)
Member
I just had this same job done on my T-Cat with electric start and reverse. Dealer charged $200.00
Biggus is offline   Reply With Quote
Old 02-07-2009, 09:06 PM   #7 (permalink)
snochopper's Avatar
Current Sled(s): F-1000/2016 ZR8000 Limited
Previous Sled(s): 77 ElTigre
Favorite Riding Area: Perkin's Clearing
Riding Since: 1972
Even with reverse its a 2 hour job, $50 for parts, for $350 I'd come and do it on your cold floor!
snochopper is online now   Reply With Quote
Old 02-08-2009, 03:48 PM   #8 (permalink)
catchmeifucan's Avatar
Current Sled(s): 2012 F1100T SP LTD, 2007 Attak
Previous Sled(s): 1996 TCat 1004, PS1000 Cat
Damn, on my tcat, i would loosen track, take off speedo cable and drive adapter plate, unscrew set screw, and pop out bearing. Start to finish, 20 minutes, but I changed it every year, cos I had one let go and take out bracket.
This was for a straight bearing change that came off real easy, make take longer and may have to remove suspension, chaincase covers, gear, chain and drive axle if there are any problems. But still, get a few buddies over, a 24, and have at it.
Oh, the 24 after the install!!!
catchmeifucan is offline   Reply With Quote
Old 02-09-2009, 12:30 AM   #9 (permalink)
Apparently you must have different Arctic Cats from the rest of us.The driveshaft sticks through the edge of the tunnel slightly on mine and the hole in the tunnel is smaller than the bearing outer race so it will not come through the hole.I have thought about coming up with the idea of a double width bearing and larger mtg flange so that a bigger hole is in the tunnel ,henceforth being able to slide the bearing out the speedo side in the 20 minutes that describe.
acsnogoer is offline   Reply With Quote
Old 02-09-2009, 01:53 AM   #10 (permalink)
flyingac's Avatar
Current Sled(s): 09 CF 800 SP
Favorite Riding Area: SDR
Riding Since: 1974
You can take the bearing out from the "Speedo" side because the bearing is inside a two piece cup that bolts to the tunnel. The only hard part would be disconnecting the locking ring on the drive shaft that holds the bearing in place because it is on the inside of the tunnel. Plus you would then have to reuse the old locking ring. Better to remove the drive shaft and replace the Bearing on BOTH sides. Not worth taking the whole thing apart and reusing a $20 bearing. Did this last week on my spare sled 99 powder special, it took 2 hours and 15 min in a nice warm shop! Parts list, BOTH bearings, gasket for your chain case, and there is and O-ring inside the chain case & oil. Best of luck
flyingac is offline   Reply With Quote
