ACT shocks on artic cat - HCS Snowmobile Forums
Arctic Cat General Discussion This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. This is a 100% NO BASH ZONE. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. Posting private messages from Members or Site Staff is against site rules and will be subject to banning from site temporarily or permanently. Full Throttle Speed
Old 12-23-2003, 03:09 PM   #1 (permalink)
tcat1000cc's Avatar
Current Sled(s): 01 Thundercat & 03 ZR 900
Previous Sled(s): 99 tcat RIP, 00 Tcat RIP
Favorite Riding Area: woodford, vt
14-15 Mileage: 480 so far
13-14 Mileage: not enough
Riding Since: 1994
My friend just picked up a 02 zr 800 with 790 miles... here it is 1,100 miles later and every shock in the pig is shot. I ride my stuff harder and faster then him and never seen shocks need to be rebuilt so bad so fast. My one friend said they are garbage shocks. I took the sled for a ride and it was scary also my zrt 800 with 2800 miles handles like a dream still on all stock suspension and shocks. Hes a heavy guy around 240 LBS but still all the shocks shouldnt be shot at 1,100 miles. I told him to rebuild the rear and put in 2up coil springs or like i did with my Tcat... threw away the garbage stock shock in the rear and put in a RYDE FX 9200 series shock with beefed up coils which took care of that problem. Should he get rid of the front or rear shocks or rebuild them and get stiffer front and rear springs? What would you do?
tcat1000cc is offline   Reply With Quote
Old 12-23-2003, 03:30 PM   #2 (permalink)
Jim85IROC's Avatar
My K2 smartride shocks were so whipped at 1200 miles that you can push them in and out with 1 finger, and they stay wherever you position them..
If you think education is difficult, try being stupid.
Jim85IROC is offline   Reply With Quote
Old 12-23-2003, 03:56 PM   #3 (permalink)
fastcat800's Avatar
Current Sled(s): 2006 XF 700 & 2006 M6
Previous Sled(s): 2001 ZR 800, 1996 ZRT 800
Favorite Riding Area: MN's North Shore and WY
16-17 Mileage: 960
15-16 Mileage: 2410
14-15 Mileage: 1200
13-14 Mileage: 2500
Riding Since: 1971
ACT shocks are almost an exact copy of the fox shocks. The main difference I see is the caps are never installed as tight from the factory as the Fox shocks and they seem to be dirtier than the Fox's the first time they are taken apart. The loose caps let the nitrogen escape easier and may also allow air into the fluid end. The ACT oil is junk and always smells like a dead animal. Once propery rebuilt with good oil ACT's seem to last just as long as Fox do. Remember the manual says to rebuild your shocks after the first 200 miles. That's to get the dirty oil and junk out of the shock before it damages the shock. It's just like you do with a new car motor, run it 500 miles and change oil and filter to get all the junk out from the inital break in. Get all the shocks rebuilt and at 240 lbs heavier rear springs would help the shock life as well.
fastcat800 is offline   Reply With Quote
Old 12-23-2003, 07:48 PM   #4 (permalink)
AlexZR600's Avatar
AlexZR600 is offline   Reply With Quote
Old 12-23-2003, 10:06 PM   #5 (permalink)
tiggershark's Avatar
Current Sled(s): 2015 ZR 8000 el tigre' 2016 ZR 6000 LXR
Fastcat800, you hit the nail on the head. After 1st rebuild they will last a long time I had 8 shocks rebuilt this year--6 had air in them. I get my maintainence done in September, so I beat the crowds.............tigger
tiggershark is offline   Reply With Quote
Old 12-23-2003, 10:44 PM   #6 (permalink)
03900bigiron's Avatar
fastcat800 is rightall i seen different in the two shock's is the black coating on the shock tube and shaft.i rebuilt them useing the tool's and seal's from my 95 zrt 800 fox's.after 2800 mile's of hard riding.1 front shock leaking externally alittle and the front skid was wasted with gas in the oil.surprizingly ,the bushing and lower cap was still in excellent condition. i have ifp height's if needed....al...
03900bigiron is offline   Reply With Quote
Old 12-24-2003, 06:52 AM   #7 (permalink)
rja
it's the seals. change the seals to a quality seal such as syn-tech or dey-core and they will last much longer
rja is offline   Reply With Quote
Old 12-24-2003, 07:16 AM   #8 (permalink)
Banned
:beerchug: Dave what's your turn around time right now on rebuilding 4 remote resevoir ACT shocks? Thanks-Jim.
Judge Smales is offline   Reply With Quote
Old 12-24-2003, 06:27 PM   #9 (permalink)
f7tuner's Avatar
You can rebuild a hundred times but will never last untill you put in heavier springs
Over 200 lbs,you must install heavier springs..all three in rear skid
f7tuner is offline   Reply With Quote
Old 12-25-2003, 11:13 PM   #10 (permalink)
fastcat800's Avatar
16-17 Mileage: 960
15-16 Mileage: 2410
14-15 Mileage: 1200
13-14 Mileage: 2500
Riding Since: 1971
Jim, I am running 3-4 days for turn around right now. Dave
