f7 timing key - HCS Snowmobile Forums
Old 05-03-2010, 05:59 AM   #1 (permalink)
Newbie
is it true that if i switch timing key i could get 10 hp more in my 2005 f7, what would you recomend, 2 or 3 degres?
cbp in norway said so
f7andsx450 is offline   Reply With Quote
Old 05-03-2010, 06:16 AM   #2 (permalink)
Newbie
is it any difference, one is called offset key and the other timing key, wich one should i buy? http://www.cbp.no/sc_index.php?page=sc_webshop
Old 05-03-2010, 08:13 AM   #3 (permalink)
mikef7's Avatar
Current Sled(s): 02zrt6
Previous Sled(s): 03F7
Favorite Riding Area: The UP
Riding Since: 1975
You are getting false information. 2 or 3 degree Timing key will get 2-3 HP gain. Also remember when adding more timing you must ran higher octane fuel.
mikef7 is offline   Reply With Quote
Old 05-03-2010, 09:41 AM   #4 (permalink)
Newbie
i run 98 octane, but is it any diference on the timing key and the one called offset key, the one called offset key is 2 degres and the timing key is 3 degres, does the offset key gain more hp or?
Old 05-03-2010, 09:57 AM   #5 (permalink)
jeffh62's Avatar
Current Sled(s): 2015 F1100T LXR
Previous Sled(s): 2012 F1100T, 2010 800cfr, 2003 F7
QUOTE (f7andsx450 @ May 3 2010, 08:41 AM)
i run 98 octane, but is it any diference on the timing key and the one called offset key, the one called offset key is 2 degres and the timing key is 3 degres, does the offset key gain more hp or?[/b]
Offset key/timing key same thing. If an EFI sled 3 deg may be a bit much on 91-93 octane fuel....but if you in fact run 98 you should be good.
jeffh62 is offline   Reply With Quote
Old 05-04-2010, 01:13 AM   #6 (permalink)
Buz
Buz's Avatar
Current Sled(s): 2012 M800 Proclimb & 2010 M8 Sno Pro
Previous Sled(s): 2004 f7 EXT, 2011 M8 Limited
You're bound for trouble if you go with a 3 degree key on an efi sled. Guaranteed!!! And yes even with the high octane fuel. This all speaking from experience.
I Didn't Come Here To Get 2nd Place!!!
Buz is offline   Reply With Quote
Old 05-04-2010, 07:51 AM   #7 (permalink)
Newbie
ok, thanks for the answers, dont think i gone switch it at all if it doesn`t help that much
Old 05-04-2010, 09:19 AM   #8 (permalink)
Current Sled(s): f7 black widow
Previous Sled(s): zr900
QUOTE (f7andsx450 @ May 4 2010, 06:51 AM)
ok, thanks for the answers, dont think i gone switch it at all if it doesn`t help that much[/b]
if it is carb it will help a lot thay are way down on carb. from what i herd 05 are way down some are runing 4*
deerhunter78 is offline   Reply With Quote
Old 05-05-2010, 01:05 PM   #9 (permalink)
jerwalt3674's Avatar
I disagree that your bound for trouble with a 3 deg key. I have had them on 3 firecats, the latest has a y pipe, pipe mod, v force reeds and air box valves all with stock fuel system. 4600 miles with no trouble I always run 92-93 octane, a few times it wasn't available and I ran 87 octane and took it easy on the throttle with no issues. Cheapest improvement you can make that you can actually notice IMO.
jerwalt3674 is offline   Reply With Quote
Old 05-05-2010, 11:41 PM   #10 (permalink)
Buz
Buz's Avatar
QUOTE (jerwalt3674 @ May 5 2010, 11:05 AM)
I disagree that your bound for trouble with a 3 deg key. I have had them on 3 firecats, the latest has a y pipe, pipe mod, v force reeds and air box valves all with stock fuel system. 4600 miles with no trouble I always run 92-93 octane, a few times it wasn't available and I ran 87 octane and took it easy on the throttle with no issues. Cheapest improvement you can make that you can actually notice IMO.[/b]
Consider yourself lucky.....me on the other hand not so lucky.
