Oil adjustment seem too rich! - Page 2 - HCS Snowmobile Forums
Old 02-18-2003, 09:21 AM   #11 (permalink)
skikvt's Avatar
Current Sled(s): 2010 Renegade X etec
Previous Sled(s): 07 Polaris Switchback 600, 03 F7 SP
Favorite Riding Area: Chittenden, NEK, Pittsburg
Riding Since: 1969
Well I'm definately going to keep on yop of my ratios!
skikvt is offline   Reply With Quote
Old 02-18-2003, 09:31 AM   #12 (permalink)
Krispy- X8's Avatar
I'm keeping on yop also.
Cape Crumbleberry
Krispy- X8 is offline   Reply With Quote
Old 02-18-2003, 10:17 AM   #13 (permalink)
Wicked King's Avatar
Originally posted by Firecat_freak@Feb 16 2003, 01:18 PM
should be other way around, ethanol mode selects 3% more fuel
If you're adding more fuel, the oil mixture will be leaner and will burn cleaner. Therefore less smoke in ethanol mode.
It's Good To Be The King!
Wicked King is offline   Reply With Quote
Old 02-18-2003, 11:00 AM   #14 (permalink)
rob
Newbie
Originally posted by Wicked King+Feb 18 2003, 09:17 AM-->
<!--QuoteBegin-Firecat_freak
If you're adding more fuel, the oil mixture will be leaner and will burn cleaner. Therefore less smoke in ethanol mode. [/b]
Hmmmm... let's take a look at that.
Say you are running 50:1 with the switch in the 'regular' mode. Going to the 'ethanol' mode adds 3% more gas. 3% of 50 (the gasoline portion of the ratio) equals 1.5, so the result from changing from regular to ethanol changes your ratio from 50:1 to 51.5:1
Meanwhile your fuel to air mixture is 3% higher.
Think that will make it smoke less
rob is offline   Reply With Quote
Old 02-18-2003, 09:39 PM   #15 (permalink)
LACAT's Avatar
Current Sled(s): 2012 XF 800 50TH RETRO
Previous Sled(s): 2005 FIRECAT ,1984 ELTIGRE ,1970 PANTHER
Favorite Riding Area: GASPE' QUEBEC
Riding Since: 1968
Thumbs up
HOW COME NO ONE IS SETTING THIER OIL PUMPS TO THE LINE WHEN HELD W.O.T.!!!!!!!!!!
SNOWMOBILES OWNED SINCE 1970! -1970 ARCTIC CAT PANTHER 440-1973 ARCTIC CAT ELTIGRE 250-1973 ARCTIC CAT CHEETAH 440-1973 ARCTIC CAT PANTHER 400-1974 ARCTIC CAT PANTHER VIP-1974 ARCTIC CAT LYNX II 340-1976 ARCTIC CAT CHEETAH 4000-1976 ARCTIC CAT PANTERA 5000-1978 ARCTIC CAT ELTIGRE 5000-1979 ARCTIC CAT ELTIGRE 5000--1981 ARCTIC CAT ELTIGRE 6000-1981 ARCTIC CAT PANTERA 5000-1985 ARCTIC CAT ELTIGRE 6000-1987 ARCTIC CAT ELTIGRE 6000-1981 ARCTIC CAT ELTIGRE 6000-1979 ARCTIC CAT JAG 3000-1988 ARCTIC CAT ELTIGRE 5000-1990 ARCTIC CAT PROWLER 440-1981 ARCTIC CAT ELTIGRE 5000-1991 ARCTIC CAT EXT SPECIAL 550-1992 ARCTIC CAT EXT SPECIAL 550-1979 ARCTIC CAT JAG 3000-1979 ARCTIC CAT JAG 3000-1986 KITTY CAT-1993 ARCTIC CAT EXT SPECIAL 580-1995 ARCTIC CAT ZR 440-1995 ARCTIC CAT ZR 580-1997 ARCTIC CAT ZR 440-1998 ARCTIC CAT ZR 600-1999 ARCTIC CAT ZR 600-1970 ARCTIC CAT PANTHER 303-2000 ARCTIC CAT ZL 580-2001 ARCTIC CAT ZR 600-2001 ARCTIC CAT ZR 800-1984 ARCTIC CAT ELTIGRE 6000-2002 ARCTIC CAT ZR 800-2003 ARCTIC CAT FIRECAT F7 SABRECAT-2000 ARCTIC CAT Z120-2004 ARCTIC CAT FIRECAT F6 TIGER-2005 ARCTIC CAT FIRECAT F6 RETRO-2007 ARCTIC CAT JAGUAR Z1-2009 ARCTIC CAT CROSSFIRE 800 2010 ARCTIC CAT CROSSFIRE 800 SNOPRO ............43 TOTAL!
LACAT is offline   Reply With Quote
Old 02-18-2003, 10:56 PM   #16 (permalink)
Post
My oil pump rod took 6 turns and went from a ratio of 72 to1 to 54.8 to1. I will probably change the rod setting until I get it to 60 to1. BTW at 72 to 1 my pistons were scuffed and the rings were shot at 1600+ miles. Got it back last week with new pistons and rings and it brought the motor back to life.
mike929 is offline   Reply With Quote
Old 02-19-2003, 09:29 AM   #17 (permalink)
otterbob's Avatar
1500 miles on mine and a consistent 64:1 ratio. i am still taking it to the dealership for updates friday, but i hope it doesnt make it too rich. i am goin to have them look at my pistons and stuff but my compression seems to be good and still has great power.
Check it, add me.
otterbob is offline   Reply With Quote
Old 02-19-2003, 12:36 PM   #18 (permalink)
cat716's Avatar
Did the rod update myself. Could have gone 3 turns but only went two. I swear to GOD there was no change in oil usage - if anything it could have gone up 1 or 2 points. We'll see more this weekend - my first two rides were only 60 and 84 miles. Sled does seem to be down a bit on power (only would do 91 MPH on good hard pack _ but that was the first top end run I did with studs. 153 studs slow you down that much??? :huh: ). Pistons show no scuff marks at all but do show some blow by. Can you buy just rings?
Just when I learned all the answers they changed the questions.
cat716 is offline   Reply With Quote
