2004 Firecat F-7 EFI Sno Pro....Performance Issues? - HCS Snowmobile Forums
Old 03-23-2009, 07:36 PM   #1 (permalink)
kzr800's Avatar
Current Sled(s): 2010 Arctic Cat Crossfire LE 800
Previous Sled(s): Too Many
Favorite Riding Area: Northern Wisc. & Da UP!
16-17 Mileage: Riding
15-16 Mileage: El' Nino
14-15 Mileage: 1,000+
13-14 Mileage: 1,000+
Riding Since: 1973
Smile
I have a 2004 Arctic Cat Firecat F-7 EFI Sno Pro that I am having performance issue with. I have a Speedwerx pipe, Speedwerx Clutch kit, Speedwerx head, V-Force reeds, and 153 studs in the Sno Pro track.
Here is my problem.....It runs great up to 80 MPH, then it falls flat on its face....Top speed is 92-93MPH. I'm losing races on the top end. My sled runs great, is it possible that my track (Sno Pro) is eating that much off of my MPH? I am very dissapointed with my top end.
Any suggestions?
Thanks!
Karl (KZR800)
2008 Arctic Cat Z120
2005 Kawasaki KFX 700 ATV
2004 Arctic Cat F7 EFI Nightfire Sno Pro
2001 Arctic Cat ZR800
1999 Arctic Cat ZL600 EFI
1993 Arctic Cat Thundercat
1991 Arctic Cat EXT 530 (2)
1986 Arctic Cat Kitty Cat
1986 Yamaha XLV
1983 Yamaha V-max
1981 Scorpion Sidewinder
1981 Yamaha SRV
1973 Arctic Cat Kitty Cat
kzr800 is offline   Reply With Quote
Old 03-23-2009, 07:48 PM   #2 (permalink)
LowMediumHigh's Avatar
Current Sled(s): 2011 Sno Pro 600 XC Edition
Previous Sled(s): 2004 F5 Sno Pro
Sounds like you fucked up the clutching you sure you have the right kit for that setup. You probably need an EFI controller box too cuz with that setup your not getting the right amount of fuel without a way to manage it.
LowMediumHigh is offline   Reply With Quote
Old 03-23-2009, 08:10 PM   #3 (permalink)
MeanGreenF7SP's Avatar
Current Sled(s): Sledless
Previous Sled(s): ZR900/F6EB/F7SP/Nytro RTX
Favorite Riding Area: Drag Strip
13-14 Mileage: 25kms
Riding Since: 1982
Any suggestions?
Thanks!
Karl (KZR800)[/b]
what were the conditions like? did you look at your clutches to see how far the belt is climbing the primary? i know the speedwerx weight's do not have alot of tip weight and there clutch kits are designed sort of like sno-cross clutching.
1980 340 Spitfire / 1979 340Super Sonic
1981 5500 Blizzard / 1991 Mach 1 /1994 XLT 600SP / 2000 ZRT600
2003 ZR 900 / 2004 F6EB
2005 F7SP / 2001 SRX 700
2008 Nytro RTX/2004 F7SP
MeanGreenF7SP is offline   Reply With Quote
Old 03-23-2009, 11:38 PM   #4 (permalink)
speedstang91's Avatar
My O2, its probably in the clutching. You don't need a boondocker for the mods you have. I forget which one, primary or secondary, but draw a marker line from top to bottom and ride it. Then check and make sure the whole marker line disappeared. If it didn't, then clutching is probably off. What belt are you using?? Should use an 020 for best results. Not sure if you did it or not, but I adjusted my oil pump before I did the Big Bore when it was basically stock and that made a big difference. It could be running pig rich upstairs at WOT. I was disappointed with my top speed too when my sled stock. The sno-pro track and studs will slow you down a bit versus a standard, but you should still break the 100 mark.
speedstang91 is offline   Reply With Quote
Old 03-24-2009, 09:33 AM   #5 (permalink)
kzr800's Avatar
Riding Since: 1973
My O2, its probably in the clutching. You don't need a boondocker for the mods you have. I forget which one, primary or secondary, but draw a marker line from top to bottom and ride it. Then check and make sure the whole marker line disappeared. If it didn't, then clutching is probably off. What belt are you using?? Should use an 020 for best results. Not sure if you did it or not, but I adjusted my oil pump before I did the Big Bore when it was basically stock and that made a big difference. It could be running pig rich upstairs at WOT. I was disappointed with my top speed too when my sled stock. The sno-pro track and studs will slow you down a bit versus a standard, but you should still break the 100 mark.[/b]
I checked my clutches before my last ride and all was good. Alignment and deflection were good, and I'm pulling my belt all the way. I am running the 031 belt....Is there an advantage of running the 020? My Speedwerx pipe is supposed to run at 7800 - 7900 RPMS....I pull that too. However, I am hitting 7800 - 7900 RPMS at about 80 MPH, then it is a slow crawl from there?
1986 Yamaha XLV
1983 Yamaha V-max
1981 Yamaha SRV
Old 03-24-2009, 12:26 PM   #6 (permalink)
AZRACING's Avatar
Current Sled(s): 2 F5s & 2 F7s
Previous Sled(s): zr500
Favorite Riding Area: Lots of POW
Riding Since: 72
I checked my clutches before my last ride and all was good. Alignment and deflection were good, and I'm pulling my belt all the way. I am running the 031 belt....Is there an advantage of running the 020? My Speedwerx pipe is supposed to run at 7800 - 7900 RPMS....I pull that too. However, I am hitting 7800 - 7900 RPMS at about 80 MPH, then it is a slow crawl from there?[/b]
Is the primary spring a titanuim one, if so I've seen acouple of these bind & make it very slow to upshift after that. Also remove the springs from your clutches and put them back together w/out the springs and look for any small binding in them.
The 020 belt grabs better in the clutches, than the 031 is hard and better for high milage riding.
020 will take less primary weight to acheve the same clutching results.
THINK SNOW 24/7! If it snows today ride like there Is no tomorrow, because it maybe gone by then.
FOR SALE EFI trigger switch****only has 1200 miles $25.00
AZRACING is offline   Reply With Quote
Old 03-24-2009, 01:30 PM   #7 (permalink)
mikef7's Avatar
Current Sled(s): 02zrt6
Previous Sled(s): 03F7
Favorite Riding Area: The UP
Riding Since: 1975
020 belt is softer so it may help. You should be fine with a 031 all depends on what belt speedwerx uses as their belt on the sled they did the testing on with the 04's. At WOT the sled is pulling 7800, what happens if you let off the throttle a little bit? If the sled should gain speed then you need more weight, check this first. Also could have a spring bind issue. Put the stock primary spring back in and see what happens. Top end with the SP track should be 10-12mph faster up top then what you are currently seeing.
If all else fails post on arctic chat, Jeremy Houle from speedwerx is on the site.
mikef7 is offline   Reply With Quote
Old 03-24-2009, 10:46 PM   #8 (permalink)
Nick8692's Avatar
Current Sled(s): 2006 F7 Sno Pro
ive had my 06 f7 sno pro efi 105 on the lake and i figured that was good enought for me so i let off. do you guys think i should be getting alittle more or what.
good luck with your problem man.
Nick8692 is offline   Reply With Quote
Old 03-24-2009, 11:09 PM   #9 (permalink)
kzr800's Avatar
Riding Since: 1973
I'm so pissed off about this piss poor performance....i thought F-7's were fast!?! Now I have to wait until it snows again....In the fall, to even test these options.
I believe I have a two fold problem. The first is the Sno Pro track. The second is the clutching on my sled. I have checked it twice. I called Speedwerx and gave them a run down on the clutch, and John verified that it is the right clutch kit for my sled (Pipe and head mod)? I'm thinking about trying a different clutch kit.
Question: Should I try an ODS clutch kit (I have read good things about it), or do I try cutsom clutching?
1986 Yamaha XLV
1983 Yamaha V-max
1981 Yamaha SRV
Old 03-25-2009, 05:56 AM   #10 (permalink)
Riding Since: 1982
Question: Should I try an ODS clutch kit (I have read good things about it), or do I try cutsom clutching?[/b]
how did it work with the stock clutching?
it sounds like a clutching issue... im guessing they cut the head for more compression? how much compression are you running?
