TX-1 Recording Tachometer from EGT 12K RPM VDO - HCS Snowmobile Forums
Old 10-20-2014, 04:59 PM   #1 (permalink)
Member
Cool TX-1 Recording Tachometer from EGT 12K RPM VDO
TX-1 RECORDING TACH
Works GREAT on all....AC or DC Voltage
Snowmobiles, ATV's, Pulling Tractors, Motorcycles, Car's & Trucks!
A Total Revolution in Tachometer Design
IN STOCK!!
Available in 4 1/2" Pedestal Mount / Dash Mount & 4" Dash Mount.
Designed especially for Sleds and ATV’s, but will also work fine for Automotive Applications. this rugged built Tachometer is ready for this seasons aggressive runs. The TX-1 Records and Re-Plays the run for clearer, precise information. The Re-play offers selectable playback speed, Pause and rewind features, Cool Blue backlighting. A/C & DC operation make the TX-1 the perfect Tach. Other instrument brands have abandoned the Sled and ATV markets, but not EGT.
Place your order for the HOTTEST TACH this season!
With a TX-1 Recording Tach you can:
Monitor and Record Engine RPM.
Recall Maximum RPM.
Scroll through the recorded run on the LCD display.
Adjustable Record Time 1,5, or 10 minutes!
Review the stored run in full, or 1/3 speed or pause & analyze.
Remote Push Button to activate recording.
Record from adjustable RPM threshold.
Adjustable shift light / RPM trigger settings.
Analyze run down to 1/hundredth of second.
Use Day or Night, w/Cool-Blue backlight
100% MADE IN THE USA!
Built to with-stand harsh environments / moisture resistant.
12K RPM Limit / 4 1/2" Diameter.
Optional Shift Light can be mounted on or off the tach ,w/ adjustable brightness + $29.95
Compatible with all Snowmobile, ATV or Automotive Ignitions!
Specifics:
Power - 8-16v AC or DC voltage.
Range - Operating Temperatures 130° F to -20° F.
Accurate - Digital stepper motor design proven in racing conditions.
Versatile - The TX-1 tachometers are the only tachometers available to connect directly to distributor-less ignitions WITHOUT requiring any special tach adapter modules. This makes the installation much simpler than other instruments currently on the market.
KIT INCLUDES:
Pedestal Mount Tachometer w/ Adjustable Bracket
Wiring Harness
Remote Recording Switch / 18" Length
Click Below to Purchase!
"New" TX 1 Recording Tachometer from EGT 12K RPM VDO | eBay
Name:	EGT_12K_playback !!!(66).jpg
Exhaust Gas Technologies is offline
