Need To Tune Your Sleds Mid Range? "SHIM KITS" - HCS Snowmobile Forums
Old 10-09-2014, 01:40 PM   #1 (permalink)
Member
Default Need To Tune Your Sleds Mid Range? "SHIM KITS"
5/20 Carburetor Needle Shim Kit for Mikuni Carburetors
Twin Kit - Part# EGT-920 ($8.95)
Triple Kit - Part# EGT-930 ($11.95)
Controls Fuel metering From 1/4 to 3/4 Throttle
A standard carburetor needle has five adjustable e-clip positions that move in increments of .040" ( forty thousandths of an inch ) at a time. This large adjustment can take you from too rich to too lean ( or visa versa ). The 5/20 Shim Kit allows you to adjust your needle .010" ( ten thousandths ) at a time giving you a total of 20 adjustments instead of just five.
The 5/20 Shim Kit is easy to install and use!
IT WORKS!!
Uses existing needle. Kit consists of .010", .020", and .030" precision cut stainless steel shims, for each carb.
Twin Kit:
Twin Carb Needle Shim Kit for Mikuni Carburetors | eBay
Tripe Kit:
Triple Carb Needle Shim Kit Mikuni Carburetors | eBay
ID:	1158785   Click image for larger version
Name:	shim kit (2).JPG
ID:	1158793   Click image for larger version
Exhaust Gas Technologies is offline
